Red 206 + sound from the trunk?
08.05.2020 18:49 # 1
sahbaz24
I thought it was a plate that happened to me before, but the same plate sounds like a knocking in the trusses.
08.05.2020 18:49 # 2
kuscu38
hojam plaquesis rubbing on the trunk lid or makes noise in the form of rubbing, I understand right?
if you are not sure about the plate or its location, remove the plate, remove the plastic coating on the inside of the trunk lid, take a look at the inner assembly, there is something idle, otherwise if you take a few turns without a plate, it will cut off anyway :) but I don't think it is from the plate .. those I think are missing or If it's wrong, don't look at my fault.
08.05.2020 18:49 # 3
sahbaz24
I can't insert the plate with silicone + double-sided tape.
08.05.2020 18:49 # 4
syhkan
the screw of the punch that holds the stacking may be loose, it may make noise when there is a gap in the bumps the syhk 2014-10-09 01:10:04
08.05.2020 18:49 # 5
sahbaz24
It sounds like it's coming from inside the car
08.05.2020 18:49 # 6
206+bulent
Maybe it comes from the float in the warehouse, I hear it when I brake
08.05.2020 18:49 # 7
tigerland
Try wd40 frequently in lock me too I cut it when I squeeze wd40 in lock
08.05.2020 18:49 # 8
sahbaz24
Was it like a sheet sound in the sound from you? What does this wd40 do .d
