rectification sound
08.05.2020 16:29 # 1
eserxxx
I wonder if there could be an electric leak
08.05.2020 16:29 # 2
It forces the battery when turning the steering, I think it gives low power to the battery and there is a frequency loss or drop in the tape. that's how I set up the most logical chaining
08.05.2020 16:29 # 3
06OzGuR06
In some older vehicles, the tape is affected when it operates the wipers. It makes a scratchy due to the magnetic field created by the wiper motor. But I have never heard of it "Big & nbsp; & nbsp;
Is the steering wheel electric steering or only hydraulic?
08.05.2020 16:29 # 4
06OzGuR06
Tape is not original?
08.05.2020 16:29 # 5
What about my 2007 new chassis, my steering power? hydraulic?
08.05.2020 16:29 # 6
06OzGuR06
Then there might be a problem with their connections.
So I couldn't make much connection with the steering wheel. "Smile" There are wires on the underside of the steering column, maybe they are touching something. Check it out.
Of course, if the electronics electronics friends visit the site, they're better. They know. "Smile"
08.05.2020 16:29 # 7
scorpions_64
your sister is getting prazit tape. When turning the steering wheels, the engine runs a little too hard, which affects the charging dynamo and fluctuates in electricity slightly. the same problem is also evident in the horn. Behind the tape you need to frame the RCA inputs in common. & nbsp;
08.05.2020 16:29 # 8
yavuz25
As the man turns on the steering wheel when the steering wheel turns, the motor also fluctuates due to the light stun on the motor and feels it on the radio.
08.05.2020 16:29 # 9
06OzGuR06
Hodja, if you want to see what it looks like your problem, "Smile"
http://www.turkeyforum.com /satforum/showthread.php?p=7722985
is http://www.caraudioturkey.com/forum/elektriksel-donanimlar/parazit-sorunu-kafayi-yeycem-t41023.0.html Reviews
08.05.2020 16:29 # 10
yavuz25
[QUOTE = ezelefe] yavuz cvp for you, thank you. [/ QUOTE]
Thank you brother. gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:29 # 11
yavuz25
It is normal. As a result, the headlights blink because the engine is slightly stunned. This is not a problem. "Wink" There are in every car since we have 0 pejo. "Wink"
08.05.2020 16:29 # 12
scorpions_64
[QUOTE = ezelefe] [QUOTE = scorpions_64] your sibling tape is getting prazit. When turning the steering wheels, the engine runs a little too hard, which affects the charging dynamo and fluctuates in electricity slightly. the same problem is also evident in the horn. behind the tape, you need to frame the RCA inputs in common. & nbsp; [/ QUOTE]
tskler bro. [/ QUOTE]
unplug the tape, you will see the rca inputs for the amp output, winding all the rca from outside to outside with the bare cable. These problems have a tiny fuse inside the tape, if this fuse blown, it blows out the chassis, of course, it causes the interference of the tape, most often it happens to us in pioneer tapes. In short, there is no need to worry about a chronic malfunction :)
08.05.2020 16:29 # 13
sahin-peugeot
get well murat, same problem in me, one of the columns in my c2 car broke out
08.05.2020 16:29 # 14
sahin-peugeot
I hope there is no problem :))
of course I always wait
