Recommended Oil?
08.05.2020 19:40 # 1
burakrak53
Hi friends, Is there any oil you recommend for engine oil and transmission oil? 1.6 automatic gasoline 2004 model 307, everyone who used different oils in the forum says different things.
CASTROL MAGNATEC 5W-30 C2 STOP-START in other
Mobil 1 ™ New Life 0W-40
Most people on the internet said 10w-40. Which one will we choose? Also, what is the best brand of gearbox oil?
08.05.2020 19:40 # 2
You can use burak mobil 1 and castrol magnatec 5-30 / 5-40 / 10-40. I think you said that the gearbox had a new revision. You can use whatever oil you call as engine oil.
http://www.hepsiburada.com/mobil-1-esp-formula-5w-30-4lt-dpf-araclara-uygun-benzinli-dizel-motor-yagi-p-otyagmbl0003
http://www.hepsiburada.com/castrol-magnatec-5w-30-4-litre-motor-yagi-p-otm65a021
http://www.hepsiburada.com/castrol-magnatec-5w30-c2-4-lt-startstop-tu-benzinli-dizel-motor-yagi-p-otyagcst052
08.05.2020 19:40 # 3
burakrak53
Thanks soner :) It is time for change, I will take 5-30 or 5-40 burakrak53 2016-02-19 10:04:42
