Recommended for open air filter 406
08.05.2020 16:11 # 1
hcbank
I'm asking for suggestions from friends who use the air filter that will make a nice sound for the 406 friends. I am waiting for their advice & nbsp;
08.05.2020 16:11 # 2
metin
When we came to Ankara, when we came to Ankara, we removed the room 406 from our mimit brother. I received it from and brought it to Istanbul & nbsp; "Laugh" & nbsp; I use it in my car right now.
& nbsp;
When it comes to the
air filter, the air filter has pros and cons for me. If you press the gas, the fuel will increase and the pressure increases when the original filter is already available. "Other than that, more and better air enters the engine, the performance of the vehicle increases & nbsp; and the fuel drops (in normal use) & nbsp; 2011-10-03 16:16:39
08.05.2020 16:11 # 3
hcbank
I am aware of the fact that my brother has missed the question, when I brought the car in the car, I did not say anything when I said it sold it & nbsp; it does affect the idle I wonder, or what problems can be caused in the vehicle
08.05.2020 16:11 # 4
metin
[QUOTE = hcbank] I have news that my brother did not ask, did not say anything when I said he sold the car while bringing the mimit & nbsp; good luck affect the idle I wonder or what problems the car can cause
/ DIV> [/ QUOTE]
& nbsp;
Before installing the filter in the vehicle, there was an imbalance in idle, etc. while driving, it was due to an imbalance in the idle but I could have cleaned the throttle. then we put a filter and I couldn't see a difference. it's fine.
08.05.2020 16:11 # 5
hcbank
thank you for your attention to the help & nbsp; I am thinking of getting it installed today.
08.05.2020 16:11 # 6
metin
When you buy something good quality, 100.000 km is comfortable when you clean and care. It comes to the same account because you changed the original filter every 10,000.
08.05.2020 16:11 # 7
hcbank
Do you have any brand advice or you can say that there are 20 to 100 accessories in the accessories you can say: 50 tlye red color {yed stainless steel} & nbsp;
08.05.2020 16:11 # 8
It is supportive equipment to increase performance, but all parts need to be purchased.
It has to be bought as a set with clips made of head and pipe. I believe that it should be paid attention to have all parts of the same brand.
I use K & amp; N contributes to a nice sound and performance.
There is another brand called Pipercross which is very successful. ..
08.05.2020 16:11 # 9
hcbank
I had any problems caused by the filter after inserting it into the tool
08.05.2020 16:11 # 10
metin
[QUOTE = hcbank] Do you have any brand advice or accessories that you can say at the following prices are between 20--100 There is something like 50 tlye red {seven stainless steel} & nbsp;
& nbsp;
is important that the filter absorbs the air easily and is not affected by the temperature of the engine. According to him, pipe systems are kits etc. You should first investigate it. then you should either buy it together with the filter or compatible with the filter you received.
08.05.2020 16:11 # 11
hcbank
ok brother let me see the net saol
08.05.2020 16:11 # 12
djchaos
I just installed a new kit today, I took the simota complete kit, I did not have time to try it, but it does sound much better and stronger than before, it will affect some performance other than sound. Maybe you will not feel clear. If you look at it properly, you will use it for many years. I got the simota carbon twin charger complete set I got 199 TL with discounted pipe elbow connections my car pug 307
08.05.2020 16:11 # 13
hcbank
I looked at the kit for 406 nette, I searched for accessories, for 406 pug, there is no universal tool, they say what happens, what should I do?
08.05.2020 16:11 # 14
hcbank
this kit is not a pipe they call 2 clamps another ??? If not, would I be sanctioned in exhaust
08.05.2020 16:11 # 15
Teacher, there wasn't any problem, it shouldn't be any, there should be clamp, pipe screw etc style pieces as I said, I prefer K & amp; N and Pipercros brands.
08.05.2020 16:11 # 16
mimitt
We talked on the foot that day, and as I told you, you can get efficiency with certain brands, you will even see that the response of the accelerator pedal changes because the vehicle is 2000 cc. I recommend buying k & amp; n pipercros, simota, or green one of them, and the products you can find most comfortably on the market are k & amp; n and simota.
08.05.2020 16:11 # 17
hcbank
okay I will wait for your news
08.05.2020 16:11 # 18
metin
[QUOTE = hcbank] this kit is not a pipe they call 2 handles another ??? if not, wouldn't it be sanctioned in the exhaust [/ QUOTE]
& nbsp;
car-specific kit, from the vehicle's throat butterfly & nbsp; It is a special pipe system up to the air filter and it is designed to provide the best air to the filter installed at the end. every vehicle is different.
08.05.2020 16:11 # 19
hcbank
Thank you for your interest in the text, I left the mimite, we will handle the event, I hope I will not have anything in mind
08.05.2020 16:11 # 20
It gives you all the support for my 406 myth. Don't worry. "title =" Blink "/> & nbsp; Understand the vehicle lpg, system etc ...
Page : / 2
