Recommendations for clear sound
08.05.2020 18:11 # 1
s.seckin
it will be very useful, brother, I was wondering if I had a compenant mid bass in front of them recently, but no crossover guys tied up the tape. I have amphitheater and sub brother, I get a good sound, but the tape is very important and they deceived me.
08.05.2020 18:11 # 2
Then I think that Ali takes over this issue. :)
08.05.2020 18:11 # 3
barishrocker
Let me try to help. The strong mid sets and subs (subwoofers) we connect to the vehicle compete to remove the screws of the vehicle :) The way to cut the sounds coming is to isolate. For example, isolation membranes such as erkurt, würth, teroson are taken and adhered inside the luggage and doors. Then the heat is heated with a stranger. In this way, the jingle is prevented and the speaker performance improves.
08.05.2020 18:11 # 4
barishrocker
In addition, the most important part of the system is analogy, that is tape. The better the source you play the music, the more you get. Apart from that, the other point that is overlooked is the infrastructure. So if the car's alternator and battery are not good, you will stay on the road. The vehicle must produce electricity to feed the system. After the battery is good, the capasitor can also be installed, but not required in every system. Cables, the other element of the infrastructure, are also very important. Low and thin cables can burn the car after heating. Or it can undermine the power and sound quality of the system. Therefore, it is useful to use high quality RCA, at least 4awg power cable and 12awg speaker cable.
08.05.2020 18:11 # 5
s.seckin
[QUOTE = barishrocker] Let me try to help. The strong mid sets and subs (subwoofers) we connect to the vehicle compete to remove the screws of the vehicle :) The way to cut the sounds coming is to isolate. For example, isolation membranes such as erkurt, würth, teroson are taken and adhered inside the luggage and doors. Then the heat is heated with a stranger. In this way, the jingle is prevented and the speaker performance increases.
08.05.2020 18:12 # 6
barishrocker
In the harmony of speakers and amplifiers, ohms and rms powers are compared. Ohm event is very important. If the attention is not paid, the amp cuts. There can be 0.5, 1, 2, 3, 4, 6, 8ohm connections. Ohm changes according to the feature of the speaker. You can't say I want to connect 2ohm. The speaker feature is connected to how many ohms it is. Your amp should also support it. As for the rms powers, it is also good that your amp's rms wattage is slightly higher than your speaker. For example, 250w rms suba I connected 350w rms mono amp.
08.05.2020 18:12 # 7
barishrocker
[QUOTE = s.seckin] [QUOTE = barishrocker] Let me try to help. The strong mid sets and subs (subwoofers) we connect to the vehicle compete to remove the screws of the vehicle :) The way to cut the sounds coming is to isolate. For example, isolation membranes such as erkurt, würth, teroson are taken and adhered inside the luggage and doors. Then the heat is heated with a stranger. In this way, both the jingle is prevented and the speaker performance improves. [/ QUOTE]
well brother can we connect the mid bass without crossover? /> Lights up if you hook up the treble. Even if you just connect the midbasses, you need to adjust the frequency settings. What is your system? If you want, I will make my suggestions on the topic or continue here;)
08.05.2020 18:12 # 8
barishrocker
By the way, the most logical in terms of sound quality is to use stereo and mono amps. So at least two amps ... Also, there is an event called an active system that is very different world :)) I am currently using a 4-way active system. On the page where I introduce my car, there are also sound system details;) In the 307 section ...
By the way, SPL: bass-weighted system, SQL: both bass and sound quality are in the foreground, SQ: sound quality is in the foreground system means (active) ...
08.05.2020 18:12 # 9
s.seckin
I have 2 compenant jbl cs5c in front, 1800 watt redpower amplifier 4 outputs, 2 600 watt piaer owal speakers and 30 sony 1000 wat bass at the back.
08.05.2020 18:12 # 10
barishrocker
Let me put my car here as it will be useful. Let's not forget to say maşallah :)
[QUOTE = barishrocker] Since our family was large, we needed a little big car. I had vw polo and my father had a hyundai h100. Then we said that we will find the middle of this business :) Then, we decided on this vehicle to cut costs. Of course, a few visual elements were added to this vehicle with sound system, isolation and detailing applications.
First of all, the sound system videos of the vehicle:
Peugeot 307 SW surround sound system - YouTube
Peugeot 307 SW surround sound system .. - YouTube
These are also summary photos:
For those interested in the audio system, the assembly steps of the vehicle are here;
Peugeot307StationWagon active system video on page 20
08.05.2020 18:12 # 11
barishrocker
[QUOTE = s.seckin] There are 2 compenant jbl cs5c at the front, 1800 watt redpower amplifier 4 outputs, 2 600 watt piaone owal speakers at the back and 30 sony 1000 wat bass in addition to the original tape. : D [/ QUOTE]
Complar does not work on tape. Let them connect them to the 4-channel amp. Have the ovals connected to the tape outlet. I think you get a mono amp for Sub. Other than that, I couldn't find the tape model ..
08.05.2020 18:12 # 12
s.seckin
brother is very good :) but there is very little even the master who works in Ankara for such care :)
08.05.2020 18:12 # 13
barishrocker
There is intellectual electronics in Ankara, they are not bad either;)
https://m.facebook.com/pages/AYDIN-ELEKTRONIK-LTD-STI/178780078836276?id=178780078836276&refsrc=http%3A%2F % 2Ftr-tr.facebook.com% 2Fpages% 2FAYDIN-ELEKTRONIK-LTD-STI% 2F178780078836276 & _rdr barishrocker 2014-01-11 13:30:52
08.05.2020 18:12 # 14
s.seckin
I do not know how to get a cable to the monument.
08.05.2020 18:12 # 15
s.seckin
I think the sound efficiency will be low in the cabin without a brother, but there is a shortage of space. The luggage is small: You can get the sound you want in the cabin with the D port, but there is not much error but there are bandpass cabs that give me perfect.
08.05.2020 18:12 # 16
barishrocker
[QUOTE = s.seckin] I will have the cable of the compenants I do not know how to get a cable to the monument :) I wonder if it is connected to the amphitheater. odd even? If it's 2 pairs, just connect the mid suits to the amp. Connect the ovals to the tape outlet. For the subwoofer, it will be necessary to buy a mono amp. I couldn't find the tape model on the internet. If the amp output number is 2 or 3, you will get a very nice sound. but my advice to you is to finish this job with a little but self speaker ...
08.05.2020 18:12 # 17
barishrocker
If there is one team mid in the front and one oval in the back, connect the two to the amp. Let's set the mono amp for sub. But I think you choose your amps beautifully and I hope there are at least 2 amp outputs on the tape you buy ...
08.05.2020 18:12 # 18
EmSul
[QUOTE = barishrocker] [QUOTE = s.seckin] I will have the cable of the compenants I do not know how to get a cable to the monument :) I wonder if I can remove the amplifiers and coms on the owallaer. So you said 2 pairs or odd even? If it's 2 pairs, just connect the mid suits to the amp. Connect the ovals to the tape outlet. For the subwoofer, it will be necessary to buy a mono amp. I couldn't find the tape model on the internet. If the amp output number is 2 or 3, you will get a very nice sound. but my advice to you is to finish this job with a little but self speaker ...
The amplifier in your hand is unfortunately very simple. you will see ... nothing else will be needed
08.05.2020 18:12 # 19
barishrocker
I don't understand much when it comes to the subwoofer cabinet, but let me convey what I know. Now, if the cabin has a port, the bass will be longer. But the increase of bass means delay. So not everyone likes long bass. In this case, you have a closed box without a port. then the bass hits shorter but harder. so it's a matter of style. Both of the sub will be in one cabin, by the way.
08.05.2020 18:12 # 20
EmSul
Maşallah maşallah, I think the subject reaches its purpose
Thanks to all friends for useful information
Let's come to my system :-)
My installation materials are as follows
Tape: pioneer MVH-1400UB usb player
Columns: 2 pieces PIONEER ts-a6995s 600 watt 100 watt rms oval speaker
On the doors: 2 x 16 cm and 13 cm jbl gto-6508c and gto508c mid team
2 Pioneer ts-w 308d4 1400 watts - 400 watts rms dual coil 4 ohm as bass
Amfi: SKYTECH SKT-4014 ( http://urun.gittigidiyor.com/ev-elektronigi/skytech-skt-4014-oto-sistemleri-gt-oto-anfi-54066123 )
Mono amp: Edison ed1000d http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-oto-ses-sistemleri-amfi-edison-ed-1000d-mosfet-cikisli-3000-watt-1000 -rms-bass-amp-147956072 / detail /
How should I use the cables to be pulled completely in the vehicle installation
Is it better to have a double cabin for bass or singular? Cabins should be portlet?
Should I use Akum's new 72 amp capacitor?
If I do my insulation well, can I stop the prodigy?
Can you get a satisfying and satisfying sound with these products?
Thanks to everyone who will present an idea already
First of all, you should change your stereo amplifier and get a higher quality and strong stereo amplifier so that the sound is not inferior to 2 bass. Isolate definitely. I hope you wouldn't have any problems if you didn't get the bass amplifier edison. In this recommendation, it is better to replace your stomachs on the front doors with a quality mid suit.
If 307B 2014-01-14 05:08:09
Page : / 4
