recommendation for back door column
08.05.2020 17:38 # 1
206 ersan
friends 206 front columns do not sound very well, there is no room at the back, there is no column, what kind of column can I put on the back door, and what kind of column can I put on the bad column sound in front of it?
08.05.2020 17:38 # 2
Master, I advise you to walk around auto musicians. You will find the most suitable one. It also assembles the place you bought. You ask the person what you want.
08.05.2020 17:38 # 3
howard
column prices are not that high but I know that it is 17.5 cm that prevents it if its size is not wrong :)
08.05.2020 17:38 # 4
howard
But if you ask me, if you have a friend who goes abroad to get an even more affordable price, you can bring him both quality and affordable price.
08.05.2020 17:38 # 5
samet206
If the front doors are 16 or 16.5 CM, the back is 13 CM, if the sound is distorted, I would recommend Mids Bass - Twetter to the front. Sleepy As a midsick bass, I would like to admire the kicker. I would like to advise ... The speakers of the alpine as 13 cm are not bad.
08.05.2020 17:38 # 6
[QUOTE = samet206] If the front doors are 16 or 16.5 CM behind the back 13 CM sound is disturbed, I would recommend Mids Bass - Twetter to the front. Sleepy As a midsick bass, I would like to admire the kicker. I would like to advise ... The speakers of the alpine as 13 cm are not bad.
I also want a lot of things like this, but I don't know what a mid bass or a kicker is
08.05.2020 17:38 # 7
206 ersan
[QUOTE = Howard] but let me ask you more favorable price you get abroad to have the friend if both quality and reasonable price it can bring. [/ QUOTE] I'm going to continuously electronically the same prices everywhere to but make sure the world even turkey more advantageous
08.05.2020 17:38 # 8
[QUOTE = 206 ersan] [QUOTE = Howard] but let me ask you more favorable price you get abroad to have the friend if both quality and reasonable price it can bring. [/ QUOTE] I'm going consistently the world's onward but make sure electronics for the same price or even turkey more advantageous [/ QUOTE]
Exactly BG, there is not much difference.
08.05.2020 17:38 # 9
206 ersan
[QUOTE = hLL 206]
[/ QUOTE] I'm going to replace much of the world's bi Europe Africa in the far eastern tarafına but when china in here which is cheaper rate in expensive only exported cheap Malaysia is considered a bit of quality, but the price difference is not much none was formerly that now the turkey is just too popular ones such as mobile tlfn things like abroad it goes on sale first, but the price is not much difference
08.05.2020 17:38 # 10
[QUOTE = 206 ersan] [QUOTE = hLL 206]
[/ QUOTE] I'm going to replace much of the world's bi Europe Africa in the far eastern tarafına but when china in here which is cheaper rate in expensive only exported cheap Malaysia is considered a bit of quality, but the price difference is not much none was formerly that now the turkey is just too popular ones such as mobile tlfn things like abroad first comes on sale but the price is not much difference [/ QUOTE]
you say exactly right. but the Iphone 4 is here at 1200. TR close to 1900.
08.05.2020 17:38 # 11
Alicilik
1- There is no 17.5cm diameter speaker, let's fix it.
2- It is 165mm basically, but 160mm and 170mm can be attached.
3- The backs are 13mm.
Does your primary rear speaker line up? Check this out. Any coaxial speaker is suitable unless you wear a 13cm compenant afterwards, but it does not overpower the front ones. If you want something that will necessarily suppress, put two ovals in the back then it will press like crazy.
