Recirculation Pump
08.05.2020 13:59 # 1
ixtanbul
HELLO FRIENDS RECENTLY myself FROM 106 VEHICLE ABOUT THE ONE Arzi I WANT TO SHARE WITH YOU THE WAY YOU WHEN YOU GO HEATING COLD UFL BEGAN AND I VEHICLE tempreture MADE AND THE WAY STAY've AFTER SERVICE TAKE IT APPEARED ENTARES B FAULT OUTPUT THERMOSTAT FAN circulating PO to SAGLAM BUT recirculating pump of antifreeze AND TIME OF ALL WHEEL WHEN WE SEE THAT THE RESULTS ARE MOLDING TO THE ATTENTION OF OUR FRIENDS
NOTE: TIRİGYEL KIT IS NEED TO BE REMOVED TO REMOVE CIRCUIT PUMP.
08.05.2020 13:59 # 2
The subject has been moved from `` ISTANBUL MEMBER TOOLS '' DEPARTMENT - `` ALL QUESTIONS ABOUT YOUR VEHICLE '' Section.
Representative Friends with Forum Authorization;
We Are Still Interested In The Forum Layout. Although Your Task Sharing Is With You. !!!
- Please Check If The Topics Are Opened To The Suitable Headers.
We would like to ask you for your sensitivity and concern about the forum layout.
08.05.2020 13:59 # 3
aoc
The circulating engine is also a bleeding wound of 106 ... Even worse results can be encountered if it is not noticed early ... When the subject of heat was opened, I came directly to the heat sensor :)
08.05.2020 13:59 # 4
If we get the necessary checks on time, maybe these problems will disappear.
I think this should be a bit more in vehicles that eventually turn over ...
