Rear Wiper Problem
08.05.2020 19:59 # 1
ruhela
Hello friends,
My head has been confused for 2-3 days, I called the moderator Soner on the phone, I disturbed him a little and he made the right to look at my flaw,
The problem is that the rear wiper motor works normally when the cable is pulled from the battery, but it does not work from the arm. we tried so many things but there is none. They say it may be a problem in the arm, it is also difficult to change it, because I went to an electrician, looked, tampered, called his master, said there is a problem in the engine, said that the new engine will be fitted, I went, I researched, I bought the original wiper motor for 165 TL. The room remained in my hand, since the order came upon order, we put the man on the shelf and said whenever it was sold.
I'm waiting for help from friends who have had a back wiper shortage.
Best regards.
08.05.2020 19:59 # 2
My brother, emrah, what is halal is not a problem, you can always call. your problem may be on the arm. You will have to try and install a wiper arm. I also checked the wiper roller.
08.05.2020 19:59 # 3
Vefa
Slm, my friend has the same problem, I have 206, it doesn't work from the arm, sometimes it opens itself, closes it squeezes, but when I want to run it, it does not work.
08.05.2020 19:59 # 4
transform609
I have a 307 arm but I don't know if it will work for you.
08.05.2020 19:59 # 5
madblueblacksea
You can open and control the end of the arm. The problem I had opened for the rear window water was caused by oxidation, cleaned and installed. Before the rear window wiper works, a role is activated in the front. I do not deal with the back without engaging in this role. You can find the diagram and check it in the role.
