rear wiper problem
08.05.2020 19:14 # 1
oktobus2
friends, easy, I need urgent help
When my 2003 model 370 opened the door from the remote control, the rear wiper does not work where it should stop normally, working 3-4 times.
They said that water might have entered the BSI box. I got it installed again. As the same problem persists, this time the rear wiper works again when the vehicle is manually unlocked when the vehicle is stopped.
They call the BSI brain zero 1000 TL. Is it possible to repair. or my car's malfunction could be something other than BSI, like the wiper motor. I am waiting for your helpers .
08.05.2020 19:14 # 2
GokhaN
[QUOTE = oktobus2] good friends, I need urgent help
okay it works while the wiper motor stops and stops, it is not possible to repair the bsi related, i have not heard it properly. There seems to be no other choice than to take it.
08.05.2020 19:14 # 3
oktobus2
Dear manager, your message was not understood much. Should I replace the wiper motor or bsi
08.05.2020 19:14 # 4
talip206
The problem is bsi
08.05.2020 19:14 # 5
KILIC
oktobus2 brother when you lift the tailgate, there is a hose through which the cables pass through it. Is there any tear in it?
08.05.2020 19:14 # 6
ismailkaya
When I was holding the remote control while locking the doors in my door, it was closing my open windows, the right front window was not closing. solved, when the vehicle is at a stop, ignite the contact once, see the battery light, run the rear wipe, turn off, start the vehicle, then stop, then try to control it and see if it will fix.
08.05.2020 19:14 # 7
oktobus2
good to try I will try the first job tomorrow.
Today, I asked BSI box from the service and they said 1150 TL. Friends, does this box have any repairs around Mersin-Konya-Adana?
08.05.2020 19:14 # 8
oktobus2
I thought like you, the main electrician says BSI box that commands the wipers.
08.05.2020 19:14 # 9
oktobus2
friends, we have not found the solution for 2 years and all the mechanics I went to have fixed the problem of my rear door wipers when the door of the car is not open. When the cable was chassis due to rust, it was working because it transmitted the signal sent to BSI to open the door to the chassis wipers. At the moment, the rear wiper does not work at times.
From here I understood that every electronic fault in BS 307 is not BSI,
08.05.2020 19:14 # 10
oktobus2
MY KILINÇ BROTHER IS NOW APPROACHED TO THE PROBLEM, THANK YOU.
08.05.2020 19:14 # 11
KILIC
[QUOTE = oktobus2] MY SKILLER BROTHER THANKS TO THE PROBLEMS IMMEDIATELY IMMEDIATELY. [/ QUOTE]
Glad that the problem was solved, similar incident had happened to me.
