Rear windows do not open |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:56 | # 1 |
cetin |
| 08.05.2020 16:56 | # 2 |
cetin |
| 08.05.2020 16:56 | # 3 |
Check the F14 fuse, although we are not completely sure of the fuse number. & Nbsp;
| 08.05.2020 16:56 | # 4 |
myvzklc |
You may have unlocked the child |
| 08.05.2020 16:56 | # 5 |
if not, check the lock, insert the control and shuffle the socket a little
| 08.05.2020 16:56 | # 6 |
Friends, I have a problem in the pine of the vehicle. I'm waiting for your help. & Nbsp; Let me summarize the problem as follows. > 3- The left rear window opens and closes from the front control, but neither opens nor closes from the rear control. 4-Right rear can neither front & nbsp; control button & nbsp; nor rear & nbsp; It cannot be turned on and off from the control button. (It was opened 1 month ago, now it does not open or close from the back buttons) & nbsp; What could be the problem guys. 1-Ahead complete dismantling of the control knob cleared changing & nbsp; nothing 2- I removed the right rear button and the door trim, the cables are plugged in but not working. ) & nbsp; What would you suggest as a solution? If I change the control on the left driver's door, will it be solved? is there any other problem? div>
| 08.05.2020 16:56 | # 7 |
[QUOTE = aokaymaz] Friends, I have a problem with the pine of the vehicle. I'm waiting for your help. & Nbsp; Let me summarize the problem like this. opening and closing 3- The left rear window opens and closes from the front control, but neither opens nor closes from the rear control. 4-Right rear can neither front & nbsp; control button & nbsp; nor rear & nbsp; It cannot be turned on and off from the control button. (It was opened 1 month ago, now it does not open or close from the back buttons) & nbsp; What could be the problem guys. 1-Ahead complete dismantling of the control knob cleared changing & nbsp; nothing 2- I removed the right rear button and the door trim, the cables are plugged in but not working. 3-I also checked the child lock on the front remote control (both pressed and not pressed but still did not work ) & nbsp; What would you suggest as a solution? my car 2003 model Peugeot 307
| 08.05.2020 16:56 | # 8 |
PROBLEM SOLVED PROBLEM SOLVED Dear friends, I solved the problem in my vehicle First of all I removed the control button on the left driver's door.There is an electronic card inside this button mechanism. Again, on the same card, there are 3 pins for controlling the rear windows. The part where the rear window socket is attached is the needle, but when you remove it, you will see the metal parts entering the socket. Anyway, I removed the card, I connected the electrical sockets again, and I saw that two pins in the socket of the rear windows were broken, the solders on the upper part were broken, soldered them, the rear windows started to open from the front control. The problem started to close, I hope I could help. http://s1288.photobucket.com/user/aokaymaz/media/547193EE603C44D3AF144E49DA97E0D4_zps7baafa81.gif.html I added a picture of friends aokaymaz2013-07-19 14:00:19
| 30.11.2025 22:07 | # 9 |
The pictures are not opening, the pictures you soldered
