rear window wiper water is not coming out
08.05.2020 16:36 # 1
arslanbey01
friends 2006 peugeot 307 1.4 gasoline new chassis car needs to squeeze the water out to clean the rear window, but water does not come out, but instead squeezes the water to the windshield is the reason. & nbsp; wipers are working there is no problem wipers, but the windshield is not watering process is not happening I have congestion I wonder how you open it.
08.05.2020 16:36 # 2
aspirinxlarge
Complete the windscreen wiper water. & Nbsp; Put hot water and some anti-freeze. & Nbsp; Or they have ready antifreeze glass waters. & Nbsp; But let the water be hot. & Nbsp; Then let's see, will it unclog? & Nbsp;
08.05.2020 16:36 # 3
arslanbey01
I live in Erzurum, and my glass water is already antifreeze, but as I said, if I tried pressing hot water & nbsp;
08.05.2020 16:36 # 4
feline
my friend has frozen it, if you pushed it or if you pushed it, you burned the engine and it happened to me
08.05.2020 16:36 # 5
djchaos
I know that if the water is antifreeze, it will not freeze, though -30 even freezes the antifreeze :))
08.05.2020 16:36 # 6
I caught my attention, maybe I got it wrong, I don't know, but I was wondering whether it sprays water on the windshield and rear windows at the same time .. you mentioned your problem by squeezing it on the windshield instead of the back .. & nbsp;
08.05.2020 16:36 # 7
arslanbey01
Normally, when I run the rear wiper in my vehicle, it does not need water, but when it waits, it sprinkles on the windshield, I guess, when it cannot come out from the rear sprinkler, the water sprinkles through the windshield. I mean, I can't send water to the back window. In addition, the water motor that pumps water to the wipers becomes a form, that is, one motorized sprinkler is made on both the windshield and the rear windshield. the fault in me is that the rear wiper works when I turn the wiper knob to the last to spray it to the rear window normally, but I do not perform the sprinkler operation. After a while, the water starts to spray on the windshield. I think there is a blockage somewhere when it does not come out of the rear sprinkler, it sprays on the windshield. I would be glad if you answer how this congestion is opened or what is the solution. thanks
08.05.2020 16:36 # 8
Cmoss06
frozen because of no water coming back to the windows, hence the rushing of the windows.
08.05.2020 16:36 # 9
If the water of the rear and windscreen is connected to the same tank, you can find out whether the rear window is blocked by blowing and blowing the hose. & nbsp;
08.05.2020 16:36 # 10
altantezcan
It is not freezing, friends, because the same event is present in me, and even in my subjects, when I experienced this event, it was June, when nothing happened, it was like the same friend. last output open
altantezcan 2012-02-20 16:23:49
08.05.2020 16:36 # 11
altantezcan
[QUOTE = cigdemilker] If the water of the rear and windshield is connected to the same tank, you can find out if the rear window's hose is blocked by blowing it. ok but I couldn't disassemble
08.05.2020 16:36 # 12
artes34
Try opening the hole of the water jet with a needle, it is probably blocked.
08.05.2020 16:36 # 13
[QUOTE = altantezcan] [QUOTE = cigdemilker] If the water of the rear and windscreen is connected to the same tank, you can find out if the rear window is blocked by blowing and blowing it .. & nbsp; [/ QUOTE]
I tried a few times but I couldn't As you said, it would be obvious if we blow the pipe, but I could not disassemble it
& nbsp; I don't know exactly how a tank and a hose, I never tampered with the mentioned tool .. at least you can be sure of an experiment. clogged or is there a problem with the engine .. be careful not to break the parts anyway ...
08.05.2020 16:36 # 14
ersan
I thought there was no freezing of water on the glass. It is necessary to remove the right ten rubber to open the pump and when you remove the protection plastic completely, the glass water reservoir and the pump can reach the pump, there are two hoses connected to the pump for the rear windows, one or one piston on the end of the pump to spray water back, and that piston is clogged. worked. be careful when you open alone, it may break.
08.05.2020 16:36 # 15
Bursat
I don't want to let the matter go, but I have the same problem. Could there be any insurance related situation as if there was no clear result here? & Nbsp;
08.05.2020 16:36 # 16
Serkan
Hodja, I had the same problem. When I first got the car, the problem is that the water jet engine has a double outlet in the middle. first, the supplier industry was 15 TL and the original was 54 TL. I bought the supplier industry and there is still no problem.
08.05.2020 16:36 # 17
Bursat
Thanks a lot @ Serco05 point shot treatment is more useful :) I will handle it immediately
08.05.2020 16:36 # 18
ahmet_bjk
This happened to me in the cold weather. I left the car in the sun and dissolved the water in the water tank, but the water was not coming out again. The problem was solved when opening the outlet holes of the water with a needle. There's a lot of money for a little problem.
08.05.2020 16:36 # 19
Serkan
Sir, the problem here is that when the water gives back, the water goes to the windshield.
08.05.2020 16:36 # 20
Bursat
No, I don't think my teacher is related to water freezing because there is no cold air left. I suspect that the rear left brake light and the white lamp that stimulates reverse gear are not lit, but I will look at it at a suitable time tomorrow. I write the result here. Bursat 2013-03-13 21:25:58
Page : / 2
