Rear window wiper water
08.05.2020 19:26 # 1
lapota13
Hello friends. I have 206 vehicles, I don't know if I have a water jet or not. No water to the rear windows. If there is a fountain, why not throw it?
08.05.2020 19:26 # 2
38HT299
firstly my vehicle is 99 model 206 xr
When I spin the tip of the wiper arm on the right 2 times, water is gushing out of the stop lamp in the spoiler on the top, as far as I know, the water chamber is the moment with the windshield.
08.05.2020 19:26 # 3
38HT299
http://i.hizliresim.com/Yl80AD.jpg this is where I said there is something like a little black hole in that stop there is water coming from my car
08.05.2020 19:26 # 4
Turgutreis06
The fact that we put the tap water in the water tank cannot fully perform its function due to the lime of the sprinkler holding up and the clogging of the tank as a result of the algae of the tank. In this way, your squirts are not clogged, your tank is not moss, and insects, flies, etc. the cobwebs flow through your glass, even with a wiper without staining .....
08.05.2020 19:26 # 5
sezar206
When I turn the wiper arm in my car, it sounds, but it doesn't throw water. I did not notice it next to the lamp.
08.05.2020 19:26 # 6
lapota13
Now I looked at the back stopper yes there is a hole I tried to open the ignegle but it did not happen. What can we do ourselves?
08.05.2020 19:26 # 7
talip206
If it sounds loud or not, there may be a problem with the motor. If no water comes out, the hose may be clogged or disconnected. The rear wiper operates once you turn the knob on the wiper arm, and when you turn the second lap without leaving your hand, water sprays to the back. Since the distance is long, the water does not come out immediately. Wait a little while holding it with your hand. You will also hear the engine sound if there is no problem.
08.05.2020 19:26 # 8
Htc
The same problem happened on the peugeot 206 2001 vehicle. The water tank comes from the same place, both front and back.There is a small sprinkler in the upper taillight shown in the picture. Wash the sprinkler for 5 minutes after removing the lime remover and remove the lime with the help of a needle.
08.05.2020 19:26 # 9
xmen
probably your water sprinkler engine is faulty ... if there is no water coming to the rear window and when you run the rear window sprinkler, the engine noise is also malfunctioning ... the price is around 20-25 pounds ... i changed it recently ...
xmen 2015-09-05 20:14:43
08.05.2020 19:26 # 10
lapota13
This day I inserted the rear taillight, no water comes from the hose, I think it is okay. The sound of the engine is the same as the running fountain, but the only problem is that water does not come. I wasn't sure if the hose or the engine was broken.
08.05.2020 19:26 # 11
38HT299
the hose is clogged the same thing happened to me on my previous vehicle broadway
08.05.2020 19:26 # 12
mkalay
When my friends run the sprinkler for the windshield in my 206+ vehicle, water comes from the rear sprinkler. What's the problem?
How do I remove the sprinkler engine
08.05.2020 19:26 # 13
[QUOTE = mkalay] When my friends run the sprinkler for the windshield in my 206+ vehicle, there is also water coming from the rear sprinkler. What is the problem?
How do I remove the sprinkler motor [/ QUOTE]
How long have you been this hodja? As if they were directly attached to the front of the hose. right front wheel will be under the hood.
08.05.2020 19:26 # 14
mkalay
It was new mkalay 2018-02-27 02:22:53
08.05.2020 19:26 # 15
mkalay
[QUOTE = sonerkyl] [QUOTE = mkalay] When my friends run the sprinkler for the windshield in my 206+ car, water comes from the rear sprinkler too. What's the problem?
It was new my teacher didn't exist 5 days ago
08.05.2020 19:26 # 16
M.Ahmet059
hello in me, is that the hole or the crack, what is the water, I put the water drop by drop: D how can I disassemble it?
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
