Rear Window Resistance
08.05.2020 21:25 # 1
ocaliptus
Hello friends,
I want to share an incident with you.
There was a window film on the windows of my vehicle, the friend I bought the vehicle made. It was fine but when a window film was banned, I removed all the films myself. Here is the story of the rear window resistance I want to emphasize. I had no problems after disassembling, so the resistance was working.
As I entered the winter season , I saw that misting and resistance did not work on the rear windows. I called the electric master of the special service I was going to in Ankara Şaşmaz by phone and explained the subject. He immediately told me that when disassembling the film, the resistances were deformed, that the rear window should be replaced is not subject to repair. Was it that simple?
While doing research on the internet, I found that an auto glazier (Şeker Oto cam at Ankara Yeni Başkent Industrial Site) was repaired. Before I got there, I had another auto electrician with a wire end that goes to the resistance. I saw that the electrical shoe, which should have been attached to the rear window, was broken. The sugar master glued the shoe to the glass with a strong glue and filled it with liquid silver conductor (which I also found to be sold on the internet and electronics) to ensure electrical conductivity and the resistance was working again.
I have once again experienced that there are very few masters who know the job properly in the market, who do the job of electricity, mechanics, or engines, and who have given the subject fully. Everybody's running easy.
If it happens to me or will happen, I share it with you for help. Have a nice day.
ocaliptus 2020-01-12 15:59:03
08.05.2020 21:25 # 2
omerb
Hello, thank you for your information. Some masters say it has to change, as you say. But he says this before seeing it. He thinks so according to the information you give.
“Normally it happens when removing the window film, but maybe the fuse has blown, or its cable has been broken. Let's take a look.
he should say. Yours was a little bit hasty.
But if you say I had this problem after the window, he comes to your mind :)
08.05.2020 21:25 # 3
ocaliptus
There is no right master, no. I specifically said that it worked after removing the window film, would I not say. I know that you will only bind the subject to window film.
