rear window opens automatically
08.05.2020 19:21 # 1
czadan
I have joined your friends recently, I have a 2003 model 307 xt vehicle that I used very much, but I am satisfied with my vehicle, but because of a few unsolvable problems, I started to cool down from the vehicle. 1- 2 minutes after opening, it comes off automatically after opening, the on / off button is not activated, but when the rear window heating resistant button is turned on, the glass becomes active. There is no problem in the glass motor or card because this malfunction repeats only in winter days. works somehow. I changed the driver door buttons, the problem did not change 2. the problem is that the windscreen wiper sometimes works spontaneously at medium speed, even though the rain does not rain fast, it runs slowly at first, then hangs at medium speed
Waiting for help from you, our valuable experienced friends, thank you. I think I will love my car even more if I can solve these problems.
08.05.2020 19:21 # 2
sdttn
BSI or glass engine may be problematic, I need to make a measurement, to be able to make a definitive diagnosis, but I couldn't make sense of doing this problem in the winter.
2. The problem is; If the windshield has been replaced, the sensor can do it because it is not properly attached.
08.05.2020 19:21 # 3
KILIC
in winter, it may be that some of it is probably getting water.
08.05.2020 19:21 # 4
czadan
thank you for your attention first of all, when you wear a tape or something that you will not know about the bilateral brain of my car, the entrance area next to the windshield is closed.
08.05.2020 19:21 # 5
oxidation may occur in the sockets. we need to disassemble and clean with silicone spray all of them .. there is a possibility that it is from bsi but you say it is working now i think clean the sockets inside the door ..
08.05.2020 19:21 # 6
ALLEX
Oxidation may occur in [QUOTE = sonerkyl] sockets. we need to disassemble and clean with silicon spray, it is possible that it is from bsi, but you are saying that it is working now, I think clean the sockets inside the door .. [/ QUOTE]
Soner is right
definitely through the socket in the door.
The system perceives that the circuit is cut and completed especially due to oxidation as opening and closing.
Bsi makes summer and winter.
I suggest you try the sockets bypassing. so the question of whether or not from engines will also disappear.
08.05.2020 19:21 # 7
czadan
I understood, I will tell the master, I will try it too.
