rear window nozzle problem
08.05.2020 16:05 # 1
fordtaunus
Hello friends. My car peugeout 307SW. Despite the water coming from the windshields, it does not come from the rear window sprinkler. I disconnected the hose from the rear brake light. No water is coming. Can the engine be defective? I'm waiting for your help.
08.05.2020 16:05 # 2
Muhammet CAKIR
Generally, PEUGEOTS do not have a rear window water engine, for example, in 206, for example, all the draft pull but no engine :)
08.05.2020 16:05 # 3
speedark
Maybe there is a blockage in the hose, fasten the air and open the washers
08.05.2020 16:05 # 4
It caught my attention too, my vehicle has 306 at the back, but it is not throwing water.
08.05.2020 16:05 # 5
speedark
I have 206 xs, it was squirting water, then it started not throwing water.
08.05.2020 16:05 # 6
Burak07
I have the same problem on my rear window, it does not throw the full sprinkler, it just pours water: S, it is like holding water with a hose, flowing, going: S
08.05.2020 16:05 # 7
ahmet_koyuncu
My problem is with the windscreen washer. Whenever I wash the glass, there is a very bad smell inside. With great negligence, mold, etc. has occurred in the water tank, but as far as it looks inside the hood, speak to a place that cannot be reached by hand. My car is 306 by the way. Does anyone have solution advice on the subject?
08.05.2020 16:05 # 8
Muhammet CAKIR
[QUOTE = ahmet_koyuncu] My problem is also related to the windshield washer. Whenever I wash the glass, there is a very bad smell inside. With great negligence, mold, etc. has occurred in the water tank, but as far as it looks inside the hood, speak to a place that cannot be reached by hand. My car is 306 by the way. Do you have any solution advice on the subject?
08.05.2020 16:05 # 9
tolga35
friends, I couldn't find the rear glass water tank of my 307 while the ready topic was opened, is it taking water from the front tank ???
08.05.2020 16:05 # 10
Yeah.
[QUOTE = tolga35] friends; I couldn't find my 307's rear glass water tank when the ready topic was opened is taking water from the front tank ??? [/ QUOTE]
08.05.2020 16:05 # 11
speedark
yes there is only one tank, the water is taken from the same tank, only the engines are different
08.05.2020 16:05 # 12
aclern
[QUOTE = Burak07] I have the same problem on my rear window, it does not throw the full sprinkler, it just pours water: S, it is like holding water with a hose, flowing: S
I think your vehicle is 106. In the 106's I know the rear window is not in the form of a sprinkler because it is the same in my vehicle. The water thrower is at some point on the glass and the water flows at its own expense.
08.05.2020 16:05 # 13
ekinoks44
There may also be a blockage in the fountain. Snap it up, maybe it will improve.
08.05.2020 16:05 # 14
tolga35
thank you speedark brother ...
08.05.2020 16:05 # 15
ByHack
Unfortunately, the 307's wiper tank, even the extension hose of the tank, is attached to the ordinary. In most vehicles, this hose comes out, while you fill the water, it empties to the floor :)
In other cases, the fact that most users put fountain water into the water tank, because the sprinkler tips do not fully function as a result of the clogging of the tank, and the tank is fouled, we can deal with this problem by putting at least some of the water we put into the tank. In this way, both your squirts are not clogged, your tank is not moss, and even the insect, fly, etc. are flowing through your glass without wiping, and you have a pleasant journey without annoying spots without losing your vision .... :)
