rear trunk and license plate noise
08.05.2020 16:05 # 1
samett53
friends, I have a music system in my trunk, I could not cut the prosthetic incision from my trunk lid and plate, et al. There is necessarily no squeezed silicone, double-sided tape was not glued, is there an effective solution?
08.05.2020 16:05 # 2
muzaffer
I use the double-sided tape for the plate. I don't use the sound, but there is the most adjusting wedges for the luggage, it may be a little better if you raise them more, but it is still a more definitive solution to get help from a body shop.
08.05.2020 16:05 # 3
metin
pull the acoustic sponge into the cover. The whistle on the lid will be cut, as it absorbs the press impact.
08.05.2020 16:05 # 4
samett53
I can't put much bits, I put it back in the cover, I siliconized it, the bidet is narrowed, the ice is isolated, I will put the foam, the bidet
08.05.2020 16:05 # 5
metin
[QUOTE = samett53] I can't put a lot of bites, I put it back in the lid, I siliconized it, the bidet is narrowed, the ice is isolated, I will put the foam, the bidet
the simplest solution, not into the inside of the tailgate facing inside. It's not that thick, it already exists.
my friend had a falcon 38 sierra bass but believe there was no click. the inside edges of the trunk were always sponge.
text 2011-09-08 16:05:19
08.05.2020 16:05 # 6
musictime
I wonder if it would be appropriate if you put something elastic behind the plate, there was sound in me, I removed the black frame, there was a direct screw, I screwed it, there is no sound left now
08.05.2020 16:05 # 7
murat deniz
samet the same voice made me crazy i tried for months i couldnt eventually I figured it out with a very, very simple method. There are small cylindrical tires in the right and left bottom corners of the cover. it is clear that their corresponding parts have already been traced. stick one small tap jumper there. the process is ok Göz Kırpma But there is no sound in my license plate, you have to cut it separately.
08.05.2020 16:05 # 8
This crunching event is a very common situation in 206's ... For example, the arm that will erase from the sounding parts, Sırıtma
08.05.2020 16:05 # 9
It is beneficial to consult the insulating places, then you can do the process yourself by researching. The same is the case for me, I am thinking of doing something at a convenient time. the csall 2011-09-09 08:09:06
