Rear stop signal bulb replacement
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 17:33 # 1
cloudy_tr
In the user manual, it says that you will come to your hands by printing two tabs, but whatever I did (I did not find those two tabs already, there are many different tabs, I did not understand where you mean).
how to change the light bulb I am waiting for your help
I searched for youtube scanned 308 dismantling video I found it but it has nothing to do with 307 new chassis kompple different
08.05.2020 17:33 # 2
cloudy_tr
No friends can help
08.05.2020 17:33 # 3
ahmet_bjk
I also had the same problem in 308 but I managed to remove the lamp when I pushed the lamp a little bit ... If it will help, I can tell with a picture ...
08.05.2020 17:33 # 4
cloudy_tr
[QUOTE = 307bursa] your car 307 I think the
stop lamp in the remaining part of the tailgate, disconnect the plug-in entry from the taillight, hold the stop to the body with 2 10 key bolts, remove them and detach the stop from the car, then remove the part where the bulbs are attached from the nails to remove the rear part and replace the bulb. and replace the bulb and clean and plug it in. I'm afraid that if I do as you say it will miss the water :)
08.05.2020 17:33 # 5
cloudy_tr
[QUOTE = ahmet_bjk]
I had the same problem in 308, but when I pushed the lamp a bit, I managed to remove it ... If it will help, I can explain it with a picture ... [/ QUOTE]
Thank you very much but it is very different with 308. I found the video of 308 on Youtube, but as I said, it is different. :(
08.05.2020 17:33 # 6
leffe
you do not need to take the stop out, open the trunk, remove the flooring behind it to reach it. You will see the back of the headlights, there are 2-3 red nails. Replace the bulbs first, starting from the outer nail, snap it back into place. Replace the flooring. leffe 2013-04-29 15:32:14
08.05.2020 17:33 # 7
cloudy_tr
Guys, I was able to do the bulb replacement, but the bulb was not broken, but I changed it anyway.
I have a problem with the socket, making contactless. It works when you play by hand. I had the same problem 3 months ago in the left back socket and it got better when I got a hand. Where can I get the sockets? 6 hole socket cloudy_tr 2013-05-06 11:33:38
08.05.2020 17:33 # 8
Bugra
The problem with the sockets may be entirely dust related. I think you get a WD-40 derivative spray and clean your sockets well ...
08.05.2020 17:33 # 9
cloudy_tr
Can I squeeze and polish this wd 40 onto the entire engine assembly
08.05.2020 17:33 # 10
Bugra
[QUOTE = cloudy_tr] Can I squeeze and polish this wd 40 to the entire engine assembly [/ QUOTE]
It has lubricant and oxide solvent feature. I don't know whether to make it shine. but I think it should not be tightened with plastic parts.
08.05.2020 17:33 # 11
EErgul
[QUOTE = cloudy_tr] Can I squeeze and polish this wd 40 to the entire engine assembly [/ QUOTE] What should you do with
when the engine is cold? otherwise it should stain and you should clean the places that will warm up when you run it.
08.05.2020 17:33 # 12
athelas
I wonder if anyone knows where this socket and socket socket malfunctioned in my car. It is not related to dust. It is burnt inside but there is no problem in bulbs. I asked a few places but I couldn't find it.
08.05.2020 17:33 # 13
athelas
I called just stop in the service together with DGIS said greK change soketd the wiring necessary even if you have no turkey at the entrance of the regular price verdiler.stop dedi.soket installations in 1500 TL 205 to TL lambasına price verdiler.n to yapıcam bilmiyom.
