REAR STOP LAMPS
08.05.2020 15:06 # 1
albay32
FRIENDS MY 206 STOP LAMPS DO NOT FLASH ON 2 SIDES WHEN FIRENE IS PRESSED. THANKS FOR YOUR AID NOW ..
08.05.2020 15:06 # 2
albay32
Thumbs Up
08.05.2020 15:06 # 3
Asagidaki tabloya gore F11 ve F12 numarali sigortalar sag, sol ve ust fren lambalari icin.
28 fuse box in passenger compartment, without rear electric window (BFH28-1)
Fuses
Rating
Supply
Application
F1
Shunt
Ignition + ve
Pretensioner unit, front airbags, side air bags, BSI
F2
5A
Instrument panel
F3
FREE
F4
5A
BSI
F5
Free
F6
5A
+battery
ignition + ve
Engine management control unit, immobiliser
F7
Free
F8
10A
Coolant temperature unit, instrument panel, hazard warning, clock, multifunction display, courtesy lamp
F9
5A
BSI
F10
Free
F11
10A
Ignition + ve
Left brake light, third brake light
F12
10A
Right brake light
F13
+ battery
Free
F14
30A
Rear window power
F15
20A
Boot light, , tow-bar supply
F16
Free
F17
Free
F18
10A
Sidelamps +
Number plate light. Illumination: lighter, instrument panel, heater panel, radio, ashtray, transmission selector, switches, clock, multifunction display
F19
5A
Rear fog lamp
Rear fog lights
F20
Input/outlet
Free
F21
Free
F22
10A
Acc + ve
Glove box light, map reading lamp, courtesy lamp, clock or multifunction display, instrument panel, on-board navigation, rear window lift, rain sensor, charge warining lamp
F23A
20A
Acc + ve
Cigar lighter
F23B
20A
+ battery
Cigar lighter
F24A
15A
Acc + ve
Radio
F24B
15A
+ battery
Radio
F25
20A
Acc + ve
Front and rear windscreen wipers
F26
Free
F27
5A
Built-in system interface (BSI)
F28
Free
koliva2011-02-17 10:24:07
08.05.2020 15:06 # 4
Are not only the brake lights on? Do others work?
08.05.2020 15:06 # 5
peugeotefe
There is a sender under the brake pedal, it would be better if you look at it.
08.05.2020 15:06 # 6
albay32
ALL LIGHTS ARE BURNED ONLY WHAT DID I SEE THE FREEN SEAL WITH THE BRAKE LIGHTS NOT ON?
08.05.2020 15:06 # 7
[QUOTE = albay32] ALL LIGHTS ARE BURNED ONLY WHERE DID I SEE THE FREEN SEAL WITH THE BRAKE LIGHTS NOT ON? [/ QUOTE]
The cables may be loose. Remove it and try reinstalling it.
08.05.2020 15:06 # 8
albay32
thanks koliva my friend Thumbs Up
08.05.2020 15:06 # 9
Dewil1606
In the evening I said let me say the light bulb
My left back firen
The lamp on the tailgate is not lit with the lamp.
I would be happy if you are
08.05.2020 15:06 # 10
okan77
If 106 quixilver is the same as in the mirror, the sender can sometimes slide up and do not burn ... I think the slot was plastic, I think I might have misunderstood ...
08.05.2020 15:06 # 11
Dewil1606
I checked the client, there was no problem in him, I brought him to the electrician, he could not find a room.
08.05.2020 15:06 # 12
Mehmet Yamak
Dear Friends, first of all I will have a request from you, my car peugeot partner, the rear brake lights are not lit up. But it is lit on the back door.
08.05.2020 15:06 # 13
[QUOTE = Mehmet Yamak] Dear Friends, first of all I will have a request from you, my car peugeot partner, the rear brake lights are not lit up. But it is lit on the rear door.
First of all welcome, in order to get better help;
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
To Open the Subject of Promotion Please;
Click This Link: http://forum.peugeotturkey.com/new_topic_form.asp?FID=22
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
