Rear Seat Seat Removal (301 & C-Elysee)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:19 # 1
obayazit68
I use 301's brother C-Elysee. You are very satisfied with my car. I couldn't do it when I wanted to remove it to clean the back seat. Then I did a deep internet search, but I couldn't find any information. There is no information about this in the vehicle's user manual. I started to think that it was exactly fixed, when I tried to lift the seat upwards firmly, I looked at the two "u" in the plastic slots on the iron floor and it was held by a nail in the plastic slot. When I pushed this claw firmly against the back of the vehicle with a flat, wide-blade screwdriver, these "u" bars released and the seat was released from the seat.
Then I saw that the two "u" iron in the front of the two "u" iron in the front of the total four points at the back. While the front ones sit in plastic slots and nails here. the rear one reaches out to the trunk of the vehicle and fits into its slots there. This much.
It is good to make a warning; plastic slots are very fragile, you need to install a new one when broken, because water and dust will get inside the vehicle.
I will also put pictures if I can.
obayazit68 2019-09-24 09:18:45
08.05.2020 21:19 # 2
GokhaN
If you are not sensitive about cleaning your car, nobody will disassemble the seat. Most of the Psa group does not come to install plastic parts with delicate disassembly.
Is there a sound of wind coming from the window at c-elysee
