Rear left wheel problem persists
08.05.2020 16:36 # 1
Gokhan_S
Guys, the weather is very cold here - around 30 pm, my car & nbsp; I stayed outside for 2 days, I did not pull the handbrake and left it in gear, today we pushed the car out of place and noticed that the left rear wheel was not turning, it turns around when reversing, but as it goes forward it does not rotate as if the hand brake is pulled. What do you think is the problem please help Gökhan_S 2012-02-29 12:15:08
08.05.2020 16:36 # 2
Gokhan_S
Help please
08.05.2020 16:36 # 3
voodoo
the brake pads of the wheel and the discs may be frozen ...
08.05.2020 16:36 # 4
Gokhan_S
I put the car in the bread oven and let's see that tomorrow will be defrosted in a warm place, hopefully, no other problems will arise.
08.05.2020 16:36 # 5
peugeotefe
The springs of the pad may have been dislodged
08.05.2020 16:36 # 6
Gokhan_S
[QUOTE = peugeotefe] The springs of the pad may be displaced [/ QUOTE]
what is the expense
08.05.2020 16:36 # 7
furkan
pain god help winter hard for you paks
08.05.2020 16:36 # 8
djchaos
If the springs have been displaced, it will not be too expensive.
08.05.2020 16:36 # 9
Cmoss06
Either the pad or the pad is on the air, or it is broken inside the pad. The same has happened to 106 behind us.
08.05.2020 16:36 # 10
Gokhan_S
So you say, it has nothing to do with icing, is that another problem?
08.05.2020 16:36 # 11
Cmoss06
this is my opinion, but if there are experienced friends, they will help.
08.05.2020 16:36 # 12
Gokhan_S
I just got off, I dismantled the wheel for 2 days, the car has been standing in hot place, I poured 2 buckets of hot water, I put on the wheel now it turns, if there is no other problem, I hope
08.05.2020 16:36 # 13
Cmoss06
I'm glad you won't have a problem. "T
08.05.2020 16:36 # 14
djchaos
that means that the problem is not too big since the cold is a pleasant past
08.05.2020 16:36 # 15
Gokhan_S
Guys, I thought I had solved the problem, but it started not turning again, I took the car out of the warm place in the evening, took a tour around and suddenly noticed that it was not turning again, trying to move, as soon as I was holding the handbrake, it left me immediately.
08.05.2020 16:36 # 16
Gokhan_S
help please :( "Cry"
08.05.2020 16:36 # 17
okan4037
Look at the handbrake wire? I painted the pad the other day, the wire of the handbrake has wire inside, it was made with the paint, and it was not installed inside.
08.05.2020 16:36 # 18
Kemanyak
My friend, clean with lining spray, not with water, no matter how hot the water is, it can stick again with the remaining moisture, but I think the main problem is in the brake settings. Get checked & nbsp;
08.05.2020 16:36 # 19
Gokhan_S
there is no peugeot service here, do you think different services, for example, if I take it to ford service, what would it cost?
