Rear door harness
08.05.2020 20:02 # 1
lodos41
Hello friends. I bought speakers for the rear doors of my 2001 model 206 colorline, but there are no cables on the doors, although there are output cables from the tape. Does anyone know where the wiring is going to the back doors?
08.05.2020 20:02 # 2
talip206
If there is an exit from the tape, my teacher comes to the pole where the front door and the back door meet.
08.05.2020 20:02 # 3
lodos41
Is it under the floor covering or in the middle post?
08.05.2020 20:02 # 4
monalos
should appear when you remove the rear door cable connector. Did you remove the door upholstery? Is it coming up there or did they leave it in the mast?
08.05.2020 20:02 # 5
lodos41
I removed the door trim, but unfortunately there is no door inside. I hope it's in the mast. I will also look directly into it.
08.05.2020 20:02 # 6
Gokcesel
I did not have a cable in my car as far as the back door socket. I made a supplement into the door. Your cable is coming up to the socket.
08.05.2020 20:02 # 7
samet206
Generally, there is no wiring in 206 at the rear doors of the outlet without a speaker. However, in some models, it varies according to the model year and equipment, I think, since the infrastructure of the electrical installation is common in general, it has outputs in the tape socket and it remains in the socket or pole as soon as it comes into the door. Otherwise, it is not as easy as it is thought to draw zero installations. If you want to get data, install a strong quality speaker, if you attach a simple speaker to the back doors, it is not worth the effort.
08.05.2020 20:02 # 8
lodos41
Thanks for detailed information Samet206. I made my choice for alpine. I did not bother much about the installation cables coming up to the door socket. About the subject I will share photos soon.
