REAR 3. HOW TO REMOVE THE STOP? PROBLEM SOLVED!
08.05.2020 21:22 # 1
commandos07
Friends 2 weeks ago I bought a peugeot 207 (2010 model 1.6 HDI Dynamic Package). The exterior of the rear third tail light (red plastic part) is cracked throughout. He stuck the owner before me, but squeezed the silicone while putting it back on. I say, I will remove it again and clean it and install it properly. But I can not disassemble it. Looking inside the trunk, there is something like 2 white-transparent stoppers. It doesn't turn left and right, not the screw. I do not enter bars inside. I push, I pull, I could not get the third stop to get rid of the nails and leave it. Does anyone know how this third stop comes out? I got nervous officially, I worked for 1 hour ... It would be nice if you can help thank you ... commandos07 2019-11-16 18:38:52
08.05.2020 21:22 # 2
commandos07
When friends press 2 plastic pieces, it turns into a coke ... It is not going to come out because the stop is glued with silicone in my car, thank you I understand ...
08.05.2020 21:22 # 3
As you said, you can remove it with a simple operation. Thanks in informing.
08.05.2020 21:22 # 4
scar1ove
[QUOTE = commandos07] Friends get out of the coke when they press 2 pieces of plastic ... It is not necessary to force it out because the stop is glued in my car, thank you I understand ...
Everywhere of the 207 is inserted by hand :) It comes out when pushing the nails from the trunk is not very firmly attached. It is already attached as a compression.
I saw your message tonight. Anything sticking with silicone easily comes off with ethyl alcohol. You can easily remove anything that is glued with silicon by squeezing alcohol and waiting for 5 seconds. is my own invention.
Use lemon cologne instead of alcohol. alcohol in cologne is already only lemon flavored. he does the same job
08.05.2020 21:22 # 5
commandos07
I did not know about the ethyl alcohol business, but thanks to you I learned it. I'll try if it happens to me after that. Thank you...
