READING WITH GAS - FRENE PEDAL METHOD:
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 20:30 # 1
ALLEX
READING FAILURE BY GAS - BRAKE PEDAL METHOD: 1. Insert the key into the ignition switch. 2. Depress both the accelerator and brake pedals all the way at the same time. While holding the accelerator and brake pedal to the end, turn the key to 2 steps at the same time. (Do not start the vehicle… The lights will remain on the indicator) 4. Wait 10 seconds in this way. After that, the codes starting with ECN will appear on your hour. Write down the code. These codes are the codes that indicate the malfunction in your vehicle. Each code represents a malfunction. For example, ECN 119103 is the rail pressure error in diesel vehicles. At the end, ECN 0000 will be displayed and the screen will turn off. ECN 0000 means that errors are over. [TUBE] MqUMXeqO9Hg [/ TUBE] application: You have received the error code ECN 117103. you need to delete the last two digits of this code and search as P1111. In all codes, we delete the last two digits and search for the first 4 digits in the list. After you note the codes, you find the code with the line search in the error list you downloaded. EXAMPLESECN 117103 = P1171ECN 202521 = P2025…
08.05.2020 20:30 # 2
boruc
This is the first time I've heard about this event.
I wonder if it will be in 206
No 2002 model road computer.
Correction: I did not pay attention to the issue in the OPEL section good new forum Fitters 2017-08-15 19:46:39
08.05.2020 20:30 # 3
ALLEX
[QUOTE = boruc] This is the first time I heard this event.
Correction: I did not pay attention to the issue in the OPEL section good new forum [/ QUOTE]
It is available in almost all brands and model vehicles (OBD protocol port) produced after 2000. Even if it is not a trip computer, it is connected to the ECU with a PC or special technical equipment, and the error code is scanned and erased. you can detect and delete it yourself Wink
08.05.2020 20:30 # 4
KILIC
May I contribute.
To read the error code on the screen in opels before 2008.
After the key is inserted into the ignition, the brake and accelerator pedal are fully depressed. the key is turned one step. engine fault lamp starts to flash on the display. Let's say the yellow engine malfunction lamp flashed 1 time went out 2 seconds later it started to flash again 8 times burned out again waited for 2 seconds. Flashed 10 times, waited for 2 seconds again, flashed 3 times. We will count them. In this way, we will combine the number of flashes in the 2 second standby interval.
once in the first time,
in the second 8,
flashing 10 times in the third coincides with 0
flashed 3 times in the fourth 3
so we add a p per 1803 error code comes our error code P1803 we find what it corresponds to from the internet. That's all :)))
