RD4 TAPE USB AND AUX INPUT HK.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
21.10.2020 13:07 # 1
MustafaU
Hello guys, I am new among you, my name is Mustafa and I joined my 2009 Partner Tepee vehicle. There is a topic I want to ask you, I am opening this subject because I did not find many examples in the forum. I have an RD4 tape in my car and I did not want to spoil the originality, so I could not find the RD45 tapes I have encountered abroad, and as a result, I searched for a module that I can get usb and aux outputs to my RD4 tape. There are usb and aux modules called as sub-industry on the internet, but the prices are 800 and 3000 ₺ wanders between. The aux module is affordable at around $ 40, but I have no idea how satisfying the sound is. If anyone uses an aux module or usb module in their car, I would be very pleased if they inform them. Thank you.
21.10.2020 17:45 # 2
Sir, I bought blootooth modules directly and the sound quality was very good. https://tr.aliexpress.com/item/4000827776593.html?spm=a2g0o.productlist.0.0.7cf95895hosspw&algo_pvid=d1ef6023-6e69-492f-b178-96ef622938e2&algo_expid=d1ef6023-6e69-492f-b178-96ef622938e2-8&btsid=0bb0600116032915149724603e156d&ws_ab_test= searchweb0_0, searchweb201602_, searchweb201603_
21.10.2020 17:49 # 3
MustafaU
Thank you very much for your answer and the link you provided. If there is a bluetooth module, I just want to listen to music. Did you experience disconnection etc. while using it?
22.10.2020 18:10 # 4
No, teacher, there was no such problem. I was on the vehicle for about 6 months, then I had to sell my vehicle.
22.10.2020 18:33 # 5
MustafaU
Thank you very much, when I have money for your answers, I will take it at the earliest opportunity, make an assembly and explain in detail, so maybe other friends will also work.
26.10.2020 10:42 # 6
[QUOTE = MustafaU] Thank you very much, when I have money for your answers, I will take it at the earliest opportunity, make an assembly and explain in detail, so maybe other friends will also work. [/ QUOTE] Please, sir. We will be waiting for your posts, teacher.
27.10.2020 23:26 # 7
emirksk
[QUOTE = sonerkyl] teacher, I bought direct blootooth module and the sound quality was very good. https://tr.aliexpress.com/item/4000827776593.html?spm=a2g0o.productlist.0.0.7cf95895hosspw&algo_pvid=d1ef6023-6e69-492f-b178-96ef622938e2&algo_expid=d1ef6023-6e69-492f-b178-96ef622938e2-8&btsid=0bb0600116032915149724603e156d&ws_ab_test= searchweb0_0, searchweb201602_, searchweb201603 _ [/ QUOTE] how is the connection of this device? Does it appear in the bluetooth part of the road screen after the application? I had the original bluetooth in my vehicle, but the bluetooth menu is disabled now because the bt module is defective.
28.10.2020 08:53 # 8
[QUOTE = emirksk] [QUOTE = sonerkyl] My teacher, I bought blootooth module directly and the sound quality was very good. https://tr.aliexpress.com/item/4000827776593.html?spm=a2g0o.productlist.0.0.7cf95895hosspw&algo_pvid=d1ef6023-6e69-492f-b178-96ef622938e2&algo_expid=d1ef6023-6e69-492f-b178-96ef622938e2-8&btsid=0bb0600116032915149724603e156d&ws_ab_test= searchweb0_0, searchweb201602_, searchweb201603 _ [/ QUOTE] how is the connection of this device? Does it appear in the bluetooth part of the road screen after the application? I had the original bluetooth in my car, but the bluetooth menu is disabled because the BT module is defective. [/ QUOTE] Unfortunately, my teacher uses this direct aux output. In order to be original, you have to replace your defective module.
02.11.2020 10:36 # 9
emirksk
[QUOTE = sonerkyl] [QUOTE = emirksk] [QUOTE = sonerkyl] My teacher, I bought the blootooth module directly and the sound quality was very good. https://tr.aliexpress.com/item/4000827776593.html?spm=a2g0o.productlist.0.0.7cf95895hosspw&algo_pvid=d1ef6023-6e69-492f-b178-96ef622938e2&algo_expid=d1ef6023-6e69-492f-b178-96ef622938e2-8&btsid=0bb0600116032915149724603e156d&ws_ab_test= searchweb0_0, searchweb201602_, searchweb201603 _ [/ QUOTE] how is the connection of this device? Is it on the bluetooth part of the road screen after application? I had the original bluetooth in my car, but the bluetooth menu is disabled because the BT module is defective. [/ QUOTE] Unfortunately, my teacher uses this direct aux output. To be original, you have to replace your defective module. [/ QUOTE] connection. How do you have a schema? multimeter etc. I think I can do it myself I connected the aux cable myself.
02.11.2020 11:06 # 10
MustafaU
Thank you very much, I recently updated the cruise control to my vehicle and I made pandizot and center console applications from the board.I will share them in detail in my first available time, maybe it will be useful to a few friends and I will also share the central heating problem, which is a chronic problem in these vehicles. In this way, I will provide many updates whenever I find time, maybe it will be a guide for friends who like to work.
04.11.2020 11:27 # 11
[QUOTE = MustafaU] Thank you very much, I recently updated the cruise control and made pandizot and center console applications from the board.I will share them in detail in my first available time, maybe it will be useful to a few friends and I will also share the problem of the central heating in these vehicles. In this way, I will provide many updates whenever I find time, maybe it will be a guide for friends who like to work. [/ QUOTE] Nedemek teacher, we are waiting for your work.
04.11.2020 15:05 # 12
ruhela
In a study, let it come from me, although there is no aux output in all rd4 tapes, if your car does not have an aux connection, you only need to take that cable and turn the aux input on the computer as input 1 input 2. When you press the source on the tape, it means that if the input on the information screen changes as input 1 input 2 radio, it means that there is no need for a device to be connected to sound. If I were you, I would open the inputs on the tape, find the scheme, find the aux inputs from the back of the tape, fit the socket there, and connect the apparatus on the link I gave. You can still get the aux cable if you want it original. I gave. Every time I start the tool, the phone automatically connects, mic in the module. I cannot make a call because it is not available, but when the phone rings, I am talking on the phone when I turn it on from the car speaker. Sound quality is also very good. I wish you good forums.
04.11.2020 15:56 # 13
MustafaU
You are talking about a really nice work, a very useful work for many friends. It seems to me that the most logical idea to use without disturbing the originality as a result of my research is to buy a female aux socket and connect the "Baseus" brand bluetooth car module to the aux. The product reviews are really great. I hope I can find the original and fit I was looking for. Nowadays, I can not move much due to the material, but I will give a detailed explanation in my first application. Baseus Bluetooth car module (powered by USB!): LINK
04.11.2020 23:58 # 14
ruhela
Greetings, believe me, there is no difference between the product I gave you in the link and your product. You can believe it. Wait for me a little bit :) I have a loss of time when I say rim etc, let me go over them a mik. I have a circuit, I am thinking of trying it, if it happens, I will make it possible to make a phone call. 110 TL for that device, the only plus is blue. Be 5.0. If you get the empty circuit on it already 20 25 TL that is already blue. 5.0 your phone should also support it. Meanwhile, the original front speakers of the car were giving scratches, huh, I bought front speakers for 200 TL because they said huh.
10.11.2020 11:53 # 15
MustafaU
Frankly, I am trying to make the work both a little original and compact without any effort. My Tepee has both heavy maintenance and the rear speakers have started to pop, I guess I will go on as well:
