RCZ technical specifications
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » RCZ
08.05.2020 16:38 # 1
Specifications Name: Yearling 1.6 THP 156 hp Automatic Yearling 1.6 THP 200 hp Asphalt 1.6 THP 200 hp Vehicle Class: EE E Fuel Type: Gasoline Gasoline Gasoline Engine Volume: 1598 cc 1560 cc 1560 cc Number of Cylinders: 4 4 4 Engine Power: 156 HP 200 HP 200 HP Maximum power rpm: 6000 rpm 5500 rpm 5500 rpm Torque: 240 Nm 275 Nm 275 Nm Maximum torque speed: 1400 rpm 1700 d / d 1700 rpm: 0 to 100 km / h acceleration: 8.4 s 7.5 s 7.5 s Speed: 213 km / h 237 km / h 237 km / h Fuel consumption in the city: 10.3 lt 9.1 lt 9.1 lt Fuel consumption outside the city: 5.5 lt 5.6 lt 5.6 lt Combination fuel consumption: 7.3 lt 6.9 lt 6.9 lt Number of Doors: 2 2 2 Body Type: Coupe / 2 Coupe / 2 Coupe / 2 Length: 4287 mm 4287 mm 4287 mm Width: 1845 mm 1845 mm 1845 mm Height: 1359 mm 1359 mm 1359 mm Axis range: 2612 cm 2612 cm 2612 cm Empty weight: 1297 kg 1297 kg 1297 kg Carrying capacity: 463 kg Load weight: 1760 kg 1780 kg 1780 kg Front Tire: 235/45 R 18 235/45 R 18 235/4 5 R 18 Rear Tire: 235/45 R 18 235/45 R 18 235/45 R 18 Fuel tank: 55 lt 55 lt 55 lt Luggage Volume: 321 lt 321 lt 321 lt Gear: Automatic (T6) Flat (M6) Flat (M6) Traction : Front-wheel drive Front-wheel drive Front-wheel drive Number of Seats: 4 4 4 cigdemilker2012-03-16 16:16:13
08.05.2020 16:38 # 2
Nice values. After that car is at the bottom, it probably cannot match the specified fuel values & nbsp; "LOL"
08.05.2020 16:38 # 3
voodoo
super bi tool & nbsp;
08.05.2020 16:38 # 4
106fb
Does anyone know the difference of horsepower is due to which part of the engine is different?
08.05.2020 16:38 # 5
cey cey
beautiful vehicle produced peugeot again
outside seeing
and it wasn't good to use.
08.05.2020 16:38 # 6
[QUOTE = cey cey]
outside seeing
how to drive and use is not
[ / QUOTE]
my Lord, share it with us and enjoy using it ..
08.05.2020 16:38 # 7
[QUOTE = 106fb] Is there any difference between horsepower and which part of the engine is different? So there is a difference in horsepower. Reviews
08.05.2020 16:38 # 8
volkanik
friends I have a friend who has rcz in the forum, I wonder what kind of handling it is, I heard that there were skews in the bends, but I don't know if it is true, in appearance & nbsp; great tool ..
08.05.2020 16:38 # 9
grkmsngr213161
One of the most legendary series of the Peugeioot is RCZ. If new models were produced & nbsp;
