RCZ MOVEMENT PROBLEM
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » RCZ
08.05.2020 18:12 # 1
sibelozturk
Hello Today, while driving on the road, there was a message that the engine heat failure stop the car, and then the text disappeared. After half an hour I stopped the car gave the same warning when I started it again. It started to descend to 90 and after a little bit of gas, the fan started to work again, while these things were not moving, the car started to cause a problem to me without stopping 1 week ago, it was out of service. The brain of the car had changed.
Thank you in advance for your help
08.05.2020 18:12 # 2
Do you know the engine type of your vehicle?
08.05.2020 18:12 # 3
Alicilik
Most likely there is air in the radiator. Or thermostat
08.05.2020 18:12 # 4
Turgay_66
Hodja, I had read somewhere, there are many people who have experienced this problem, someone who had solved it by changing the water addition cap, I suggest you try it.
08.05.2020 18:12 # 5
When One of the Sender on Your Vehicle's Engine Detects a Certain Temperature, It Activates the Fans (Fan Sender) Another shows the Temperature in the Hands.
There is a problem with the radiator, I feel the impression that the fan does not start on time, I would recommend taking your car to the Peugeot Service and explain the situation again as soon as possible!
serkan1923 2014-01-11 21:21:38
08.05.2020 18:12 # 6
Why has the car's brain changed? If antifreeze was changed in the service or something, the radiator may have air. I do not think there is a problem with fan discharge or thermostat.
08.05.2020 18:12 # 7
sibelozturk
He had an accident, so he changed many parts from the left corner. I do not know if there has been any change of 700 km left for 20.000 maintenance.
08.05.2020 18:12 # 8
sibelozturk
[QUOTE = Turgay_66] Sir, I have read somewhere, there are a lot of people who have experienced this problem, I would suggest someone try to change it by changing the water addition cap. Good luck. [/ QUOTE]
I would understand if I was a man, I would open it and do something. My friend checked the water level, there was no shortage in water.
08.05.2020 18:12 # 9
sibelozturk
[QUOTE = SerKan1923] Activates Fans When One of the Clients on Your Vehicle's Engine Detects a certain temperature (Fan Sender) Another shows the Temperature in the Hands.
I had an accident recently, the brain of the car has changed but the fan of the car was working while driving before the accident, it did not give any heat problem. When I called the service and asked, I was wondering what they said was a problem for the sender. I have been dealing with the problem for 3 months
08.05.2020 18:12 # 10
sibelozturk
[QUOTE = dogancanguden] Why has the car's brain changed? If antifreeze was changed in the service or something, the radiator may have air. I do not think there is a problem with fan discharge or thermostat. [/ QUOTE]
I had an accident from the left corner, so it has changed so many parts. I do not know if there is any change, 700 km left for 20.000 maintenance
08.05.2020 18:12 # 11
sibelozturk
[QUOTE = Buyer] Most likely there is air in the radiator. Or thermostat
fan is always working is normal, when I start the car, the sound of the fan is coming, when there was no problem in heat, it gave the heat problem for the first time
08.05.2020 18:12 # 12
[QUOTE = sibelozturk] [QUOTE = SerKan1923] Activates Fans When One of the Clients in the Engine of Your Vehicle Detects a Certain Temperature (Fan Sender) Another shows the Temperature in the Hands.
I had an accident recently, the brain of the car has changed but the fan of the car was working while driving before the accident, it did not give any heat problem. When I called the service and asked, I was wondering what they said was a problem for the sender. I've been dealing with the issue for 3 months [/ QUOTE]
Take Your Car To The Service At The Peugeot Dealer Area As Soon As Possible `` Not To Peugeot Services! ''
I don't want to mislead you. The problem I guess will come out. Great chances, the room is not a problem that will be solved in a long period of time!
serkan1923 2014-01-11 21:51:36
08.05.2020 18:12 # 13
sibelozturk
[QUOTE = SerKan1923] [QUOTE = sibelozturk] [QUOTE = SerKan1923] When One of the Customers in the Engine of Your Vehicle Detects a certain temperature, it activates the Fans (Fan Sender) and the Other shows the Temperature in the Needle.
I called the service but they will look on Monday but they connect it to the computer and they said the part should come, I do not know for the fever, if it happens, it will be extended because
08.05.2020 18:12 # 14
Alicilik
[QUOTE = sibelozturk] [QUOTE = Buyer] Most likely there is air in the radiator. Or thermostat
continuous operation of the fan is normal, when I start the car, the sound of the fan is coming.
The sensor, which senses the motor temperature, is transmitted to the brain and the brain gradually operates the fan at certain temperature values. For example, if your vehicle's rated engine temperature is in the milk of 100 degrees, the fan operates at low speed until the engine temperature of the vehicle drops to around 90 at the 1st stage. If it is over 100 degrees, it starts to work more rapidly at 130 degrees such that it can cool down quickly. The fan stops when you stop your vehicle. The engine temperature tries to stabilize according to the temperature of the air, so if the engine temperature is detected in 90 degrees milk when you start the vehicle again, the fan continues to work again, this is a normal situation.
I recommend you to go to the service. If the water level (including antifreeze) is normal, the problem may be caused by the thermostat or the sensor that detects the engine temperature.
08.05.2020 18:12 # 15
[QUOTE = Buying] [QUOTE = sibelozturk] [QUOTE = Buying] There is probably air in the radiator. Or thermostat
The Fan May Not Stop Every Time The Vehicle Stops!
serkan1923 2014-01-11 22:00:21
08.05.2020 18:12 # 16
sibelozturk
the fan is running even though the car does not need to cool down, it works even after 1 hour when I turn on the ignition
08.05.2020 18:12 # 17
Alicilik
[QUOTE = serkan1923]
Abi is a fan in the new generation vehicles, directly connected to the contact. When he stopped at the old tofaş falcons, the fan's work.
Come on, the passion temperature sensor or the thermostat faulty fan has been running all the time. Smile the factory is not at this risk.
08.05.2020 18:12 # 18
Alicilik
the fan is running even though the car does not need to cool down, it works even after 1 hour when I turn on the ignition [/ QUOTE]
As the service says, the error you mentioned is about technical review and error searching. What we say here is empty. The service needs to look for an error and find out where the problem is.
08.05.2020 18:12 # 19
[QUOTE = Acquisition] [QUOTE = serkan1923]
How many times have I witnessed the Hyundai Coupe Genesis in VW Scirocco R. And In Many Other New Model Vehicles Indeed Not Long Term! :)
08.05.2020 18:12 # 20
sibelozturk
[QUOTE = Acquisition] [QUOTE = sibelozturk]
thank you
Page : / 2
