Rcz Ignition failure
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » RCZ
08.05.2020 19:48 # 1
Rczzz
hello peugeot family, i have rcz.
1-) In the morning, excessive flickering, irregular engine noise rinsing etc ... sometimes you can stop if you leave idle (it gets better when it gets hot). When you open it in the hood, the car engine is like a washing machine walking jerkily.
2-) There is a fall from traction. he can't take over, shit, sometimes crack exhaust. Even if the car is hot. I can't feel the old torque power.
3-) There is a smell of gasoline when working in the car.
4-) It gives high pressure pump and ignition failure. cylinder 1 cylinder 2 misfire etc.
he is writing.
we did a long term research and will do the following interventions. Sometimes you have to follow your own business. Very few professional masters in turkey. They cannot establish the cause and effect relationship. They say the coil will change, brother. The coil turns on again after 15 days. They can't solve the real reason.
The interventions in my mind are;
1-) I will have the hydraulic valve thrusters checked and replace the defective ones.
2-) If there is soot holding on cylinder head and valves, it will be cleaned.
3-) coil spark plug set will be taken new
4-) High pressure pump and gas pump will be checked.
5-) all parameters, turbo pressure etc .. will be carefully monitored on the computer
6-) catalytic convector will pass control
7-) egr valve will go through control
8-) manifolds will be checked
9-) map maf sensors will be checked
10 -) sente setting will be checked.
In addition, do you have another idea?
08.05.2020 19:48 # 2
+ I would like to have the injectors checked.
