Rcz engine malfunction
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » RCZ
08.05.2020 18:37 # 1
sibelozturk
Hello, I have a rcz vehicle, 2012 model, yesterday, engine failure, a light came on to repair the car. They said it could be burned again. There was no problem since I got out of service. This evening, there was a problem in the press because of the light burned again. The service said no problem, it burns again, it got stuck in my head. I'll be pleased if you pay attention.
08.05.2020 18:37 # 2
Advantan
If there is no error when connected to the computer, one of the sockets is probably loose.
08.05.2020 18:37 # 3
tigerland
Chronic malfunction in peugeot. Exhaust catalyst is the 2nd sensor error. If you asked the error code, I wish it would look detailed when the pc was connected, ignite it or ignite it.
08.05.2020 18:37 # 4
Barut
If it is of poor quality, the engine fault light will be on.
08.05.2020 18:37 # 5
Serkan
The exhaust and fuel related errors give the errors as in the bottom picture, I think there is another problem, but the main problem is that the service says no problem, there is a problem, the vehicle tells us this. I think show it to another service.
08.05.2020 18:37 # 6
sibelozturk
Hello, when I started the car this morning, it disappeared again.
08.05.2020 18:37 # 7
sibelozturk
08.05.2020 18:37 # 8
sibelozturk
[QUOTE = Serkan] The exhaust and fuel related errors give the errors as in the bottom picture, I think there is another problem, but the main problem is that the service says no problem, there is a problem, the vehicle tells us this. I think show it to another service.
Is it the same mistake?
08.05.2020 18:37 # 9
Serkan
The picture I added, I guess it will give exhaust related errors in Rcz of 3008 in the same way. What fuel do you use?
08.05.2020 18:37 # 10
sibelozturk
[QUOTE = Serkan] The picture I added, I guess it will give exhaust related errors in Rcz of 3008 in the same way. . What fuel do you use? [/ QUOTE]
I have been buying gasoline from the same place since I bought the car. 95
08.05.2020 18:37 # 11
tigerland
Does the service offer 95 for rcz? I always get 97, I think try the same money 97 .. tigerland 2014-06-15 23:29:01
08.05.2020 18:37 # 12
Alicilik
The vehicle did not work on this octane issue in 508.
Is there DPF, he can do it in this staple. Without complete regeneration, the engine fails.
