rapid blinking of the right signal ...
08.05.2020 17:28 # 1
ugursahin
Dear forum residents, about 2 months ago, I replaced the fender signals with the original peugeot transparent signals, until now, it was okay, but when I signaled to the right for the last 3-4 days, the signals start to flash quickly, I said that the steering wheel is returning back to normal after a full turn, did I see the signal bulbs break out? I wonder why is he doing this? there is no problem with the left signal.
ugursahin 2013-03-29 18:56:24
08.05.2020 17:28 # 2
fexzi
There may be oxide in the housing or it has chassis, have the bulbs checked on the right.
08.05.2020 17:28 # 3
ugursahin
[QUOTE = fexzi] may have oxide in the socket or it has a chassis, have the bulbs checked on the right side. But all the signals are clean. All of the signals are new rear stops 206+.
08.05.2020 17:28 # 4
Give the signal, go out and see which lamp is not on, and apply the required lamp.
08.05.2020 17:28 # 5
ugursahin
[QUOTE = 307bursa] cables may be short-circuited, any of the front and rear fender signal sensors may be oxidized or leak. One of the bulbs may be defective. br />
Could you tell me how I would do those checks.
08.05.2020 17:28 # 6
ugursahin
[QUOTE = koliva] Turn the signal out, check which lamp is not on and do the necessary application.
I checked, no light bulb broke.
08.05.2020 17:28 # 7
Ahmet_ach
bulbs are intact non-contact oxidation, or there is a flasher failure left behind.
08.05.2020 17:28 # 8
[QUOTE = ugursahin]
I checked, no light bulb bro. [/ QUOTE]
So the wattage of the lamp you installed is higher or lower than it should be. Reviews
08.05.2020 17:28 # 9
angarya0061
Have your flashes checked.
08.05.2020 17:28 # 10
samet206
most likely in flashers ...
