rain sensor gel
08.05.2020 19:46 # 1
sckn22
The rain sensor was working irregularly on my vehicle, because the glass changed, the installer could not do it properly. He took it to a glazier in the industry, so that if he changed his gel, he thought that if there was dirt, dust, etc., he said that their gels are not sold separately. It has improved a little, but due to its very fast operation, I boldly removed and cleaned and installed it today, it would be nice if I clean it a little more, and it will be more beautiful. In the last service, I asked the gel or pad, whatever it was, was not sold separately. If my problem is the gel sticking the pad to the glass with the sensor, all of my problem will be solved. Isn't there a place where I can get this?
08.05.2020 19:46 # 2
I do not remember precisely my teacher, but some auto glassmakers do it. there are even sites that sell this gel abroad http://www.gpat.co.uk/shop.php?s=510
08.05.2020 19:46 # 3
http://www.ebay.com/sch/i.html?_odkw=ya%c4%9fmur+sens%c3%b6r%c3%bc+jeli&_osacat=0&_from=r40&_trksid=p2045573.m570.l1313.tr0.trc0. h0.xsens Air + Tack + 1 + Rain Sensor + + + Regenerator gel.trs0 & _nkw = 1 + Rain Sensor + Tack + + + Sensor + Regenerator Gel & _sacat = 0
08.05.2020 19:46 # 4
sckn22
[QUOTE = sonerkyl] http://www.ebay.com/sch/i.html?_odkw=ya%c4%9fmur+sens%c3%b6r%c3%bc+jeli&_osacat=0&_from=r40&_trksid=p2045573.m570.l1313 .TR0.TRC0.H0.XSensor + Tack + 1 + Rain + Sensor + Regenerator + Gel.TRS0 & _nkw = Sensor + Tack + 1 + Rain + Sensor + Regenerator + Gel & _sacat = 0 [/ QUOTE]
This compatibility my car 2006 307 2 link comes out
08.05.2020 19:46 # 5
http://www.ebay.com/itm/rain-light-sensor-replacement-kit-type-3-4-13-/282008081055?hash=item41a8fdd29f:g:gpuaaosw~ovwztnk
this product compatible teacher
08.05.2020 19:46 # 6
sckn22
Now I went to the industry there was a gel called sensor track 1 I hope I bought it.
08.05.2020 19:46 # 7
[QUOTE = sckn22] Now I went to the industry there was a gel called sensor track 1 I hope I bought it.
I hope my teacher works without a sensor.
08.05.2020 19:46 # 8
crazysado
If you remember Soner, I had a problem with the sensor, I changed the sensor glass, it was fixed.
08.05.2020 19:46 # 9
[QUOTE = crazysado] If you remember Soner, there was a problem with the sensor I changed the sensor glass, it was fixed [/ QUOTE]
Yes, your glass was broken, our friend does not have a gel.
08.05.2020 19:46 # 10
mhmtclb
My teacher always works at the level when I get into troublesome automatics, there are formations in the form of air bubbles, the sensor part is not sitting on the glass, also, my glass is broken and it is repaired with silicone.
08.05.2020 19:46 # 11
In other words, if my teacher has a photo, a healthier comment can be made. If it is broken then it is not very healthy repairing the problem by itself.
08.05.2020 19:46 # 12
mhmtclb
08.05.2020 19:46 # 13
mhmtclb
This is the state of the sensor, teacher. it is not clear where I call it broken, it is as small as a nail, only if you look from the back seat and burn the right angle, it becomes clear that it was repaired in time
08.05.2020 19:46 # 14
sckn22
[QUOTE = sonerkyl] [QUOTE = sckn22] Now I went to the industry I had a gel called sensor track 1 I hope I bought it.
Unfortunately my teacher did not work, I threw 50 tl LOL I applied the gel, after a while like silicon, I started drying it slightly. I am not sure if there is a gel between my sensor and the glass.
08.05.2020 19:46 # 15
ramtas
your sensor has air between the glass and the gel will sit right due to the gap. It doesn't work when there is air in between. Hopefully mine works if a drop falls on the glass.
08.05.2020 19:46 # 16
sckn22
The problem with me is that sometimes it works properly, there is no rain on the glass and it still continues to wipe. Sometimes it runs at full speed, although there is no water in the glass. There is no problem not to perceive rain. As you said, I bought the gel to get that gap, but it didn't stop when the gel was applied.
08.05.2020 19:46 # 17
sckn22
If I think I attached it to this sensor, my pad is broken because it reacts differently with each disassembly. Is there a place where I can find this pad?
08.05.2020 19:46 # 18
I_Yilmaz
I changed the windshield today, the headlights are on, I guess what did you do with this gel event from the sensor?
