Rain sensor
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 21:24 # 1
hayrat
The rain sensor is working, but I almost can't see it in front of me. I said let me take it out today. When I removed the plastic casing, the part where the cable was attached came out and the plastic part made of silicone material remained on the glass.
08.05.2020 21:24 # 2
omerb
It is said that the sensor does not detect it because of mist or dust coming from the lower part of the sensor. You were done with a single flat screwdriver. If you were removing the sensor and cleaning the surface it looked on the glass, the event was over. You can disassemble it carefully. If you are prone.
rain sensor change (Remove)
You can also call. Maybe you will find something suitable.
08.05.2020 21:24 # 3
hayrat
Thanks i will try
08.05.2020 21:24 # 4
hayrat
The problem has been solved ... the auto glazier said that the gap was created because the part adhering to the glass came out and the beautiful and cleaned old sticky substance .... He put the gel on the part where the sensor was placed and put the upper pad on it. okay done
all 50 tl ...
08.05.2020 21:24 # 5
omerb
Get well soon.
