Rain and Headlight Sensor |
| 08.05.2020 19:45 | # 1 |
Hello there, The sensor was not working after replacing the windshield. I maintained the new gel. However, the rain sensor is working, the headlight sensor is not working. There is no error on the screen. (There was an error on the screen when both were not working) Recently, the fan front panel etc. I change it. Meanwhile, they had the headlights removed. I wonder if there is a cable etc. Could it be stuck?
| 08.05.2020 19:45 | # 2 |
Does the gel apply? What is your vehicle? Ten windows have changed rain sensor is not working.
| 08.05.2020 19:45 | # 3 |
206 ... There is a gel under that sensor and it does not work when there is a problem with that gel. The glazier applied a new gel, the rain sensor has improved but the headlights are still not working automatically
| 08.05.2020 19:45 | # 4 |
Does it give an error on the screen? Are the wipers working continuously when you put them into automatic operation, do they not work at all when you put them automatically?
| 08.05.2020 19:45 | # 5 |
I did not look at my screen, it does not work.
| 08.05.2020 19:45 | # 6 |
Cyrus35 |
I know that there is transparent gel, not gel, in the 206's. Personally, I complained about the same problem yesterday, and as a result of the research, I completely removed the rearview mirror and the sensor in my car and it was very dusty and stained. I took both the glass and the gels from the inside and cleaned it in warm water, dried it with a fiber cloth and put it back in place. Maşallahh is smooth now. If the light is on inside the sensor when you look from outside while it is automatic, it is either gel related or there is no other escape from the sensor :) |
| 08.05.2020 19:45 | # 7 |
Electricity is coming, but I didn't realize something was burning from the outside
| 08.05.2020 19:45 | # 8 |
Should there be a problem with the gel or sensor, shouldn't the rain sensor work? Don't both sensors work from the same place?
| 08.05.2020 19:45 | # 9 |
Does your headlight sensor work?
| 08.05.2020 19:45 | # 10 |
When the ignition is at level 1 (ACC mode where the battery light is lit only) I pressed the button on the end of the signal arm for 3-4 seconds and activated the automatic lighting. Active text is displayed on the screen. I'll try it in the evening. Let's write the solution to the problem in this way.
