Radio screen of 407
08.05.2020 14:18 # 1
I heard that the internal LCD in these 407s is always a problem. Mine was a lie. When the car is cold, it appears first but everything inside the car disappears immediately. What do I need to do and does it cost anything? Does anyone have any ideas?
08.05.2020 14:18 # 2
sdurmus61
I have no idea, I haven't had such a problem so far, I have 2006, but it is good to go to the service, my friend
08.05.2020 14:18 # 3
yilmaz34
A chronic problem caused by the screen, most of which are in the 407s
I also had the problem you said, I changed it because the vehicle is under warranty. If you are out of warranty, my advice is to give you a lot of money in the service.
08.05.2020 14:18 # 4
hasimayaz
This problem exists not only in 407 but also in all vehicle LCDs. Liquid crystal loses its feature as time gets hot. It is necessary to use sunshade.
08.05.2020 14:18 # 5
mabolla
Well, the same thing happened to me just as it happened to me, I was coming from the last week to the mug, from the lower right corner of the screen when I saw the boring, of course, when I saw that I was bored. Is there any solution other than changing it?
08.05.2020 14:18 # 6
thank you
Does anyone know the name of the piece that i need to buy?
08.05.2020 14:18 # 7
yilmaz34
[QUOTE = lazice] thank you
Does anyone know the name of the piece that i need to buy? [/ QUOTE]
you will get the screen directly, check it when you wear it, after you plug it in the same thing happened again it changed again.
[QUOTE = mabolla] the same thing happened to me just happened to me, I was coming from diarbakır to mugla last week, as the warm weather started to darken in the lower right corner of the screen, when I saw that I was bored badly. I'm afraid of its progress, what should I do? Is there no way to change it? [/ QUOTE]
Sometimes, sometimes the cap would be alive but there is no other way than changing it.
