Radio problem
08.05.2020 20:29 # 1
mburakaslan
In my new vehicle, the radio makes a lot of scratches. I also use company tools. I tried the radio in the same place, there is no scratch in the company car, but I have a lot of scratch in my car. What am I supposed to do?
08.05.2020 20:29 # 2
whisky
I can say that it was a bit too in my vehicle, especially it was making hum according to the speed of the vehicle. Then I put on a double religion and the sound was very clean. I do not know if I have written correctly, there is a noise gate in the new generations. If there is another solution, let's see the answers. whiskey 2017-08-03 08:27:05
08.05.2020 20:29 # 3
mburakaslan
I can't buy double now but I don't have anything but can not do anything on the current radio, so it is not possible to repair it. I love the original thing. There is a steering wheel control and the text on the middle screen is very nice.
08.05.2020 20:29 # 4
whisky
We can control the middle screen without a tape anyway, at least in my car, I think it is not in some models. The sizzling may be from the speakers, maybe the cables are broken over time, maybe the tape is hard to guess.
08.05.2020 20:29 # 5
Furkan979
I stupid and removed the antenna of my radio, which did not cause any lines, I installed a shark antenna, I removed the cekmiyod, this time, it did not attract the same way as it was before.
08.05.2020 20:29 # 6
hasayduman
It has been making very sizzling in my car for 2 years, recently I gave 150 TL and got another tape, I changed the original tape, the sizzle continues, there is no sizzle in bluetooth and aux, only on the radio.
08.05.2020 20:29 # 7
whisky
[QUOTE = hasayduman] has been making a lot of scratch in my car for 2 years, recently I gave 150 rubles and got another tape, I changed the original tape, the sizzle continues, bluetooth and aux also do not have any sizzle, only on the radio. [/ QUOTE] Then it may be from the antenna trouble
08.05.2020 20:29 # 8
hasayduman
I never disassembled the antenna, I did not try it, citroen and pejo in this french vehicles also have this problem of pulling, even those who use antenna amplifier (attraction enhancer) according to what they wrote in other forums.
08.05.2020 20:29 # 9
mburakaslan
So you say that this radio problem has no solution as far as I understand. But I need a tape change, did I get it right?
08.05.2020 20:29 # 10
hasayduman
Brother, I changed the tape recorder, the sizzle in me did not improve,
I will not be able to say anything to you.
Before buying tape, you need to try from an acquaintance, if it gets better, you buy.
[QUOTE = mburakaslan] So you say this radio problem has no solution as far as I understand. But do I have to change the tape correctly, I understood? [/ QUOTE]
08.05.2020 20:29 # 11
there are two options either tape or antenna cable
08.05.2020 20:29 # 12
dejawu1978
I think the tape doesn't have a chassis.
08.05.2020 20:29 # 13
mburakaslan
If I install Aux, it can also be connected to the existing vehicle and the tape aux
08.05.2020 20:29 # 14
Karacocuk24
[QUOTE = hasayduman] I have never disassembled the antenna, I have not tried it, this french car has citroen and pejo problem not to pull, even those who use antenna booster (attraction enhancer), according to what they wrote in other forums. [/ QUOTE]
I put on a frequency amplifier, believe it doesn't work.
08.05.2020 20:29 # 15
mburakaslan
[QUOTE = Karacocuk24] [QUOTE = hasayduman] I have never disassembled the antenna, I have not tried it, citroen and pejo have problems with this towing vehicle, even those who use antenna amplifier (attraction enhancer), according to what they wrote in other forums. [/ QUOTE]
I have installed a frequency amplifier, believe it doesn't work [/ QUOTE]
I think we are faced with an irrelevant issue
08.05.2020 20:29 # 16
keqir
aliexpreste got from this device
it has nothing to do with the radio but there is a product like this for those who think
08.05.2020 20:29 # 17
mburakaslan
I wonder if anyone is using this device.
08.05.2020 20:29 # 18
Karacocuk24
[QUOTE = keqir] aliexpreste var from this device
I bought the same while my friend is stationary as if it is a little bit, but if the car progresses, it does not work if it is nothing like before
08.05.2020 20:29 # 19
keqir
[QUOTE = Karacocuk24] [QUOTE = keqir] aliexpreste var from this device
I bought the same while my friend is stationary as if it is a little bit, but when the car progresses, it does not work as much as before [/ QUOTE]
Come on, I was thinking about taking it. Thank you, thank you.
08.05.2020 20:29 # 20
mburakaslan
Aux is enough to connect but who does this job and would be my tape 307 2006 model make-up safe car I have
Page : / 2
