Radio does not draw frequency.
08.05.2020 20:34 # 1
izzetcanbas
Hello friends, my car radio was on when I went to work in the morning. I calmly shifted the car to the 2nd gear after the red lights. Then, when it came to 2000 cycles, I threw the gas down to 3000 and took the gear to 3 and the radio of the vehicle started to flush. Then, when I pressed the List Refresh button while tampering, the broadcast came back, and for a few seconds, the broadcast went again. What do you think is the problem? I read the other comments and I thought if the antenna cable came out from the back of the radio because I extended the car in 2nd gear, but when I press the List Refresh button, the broadcast comes. Do I go to the service or will an ordinary electronicist understand? In any case, the CD that someone previously dropped a coin in the radio of the vehicle does not work. Did he play in money when the car accelerated?
08.05.2020 20:34 # 2
Furkan979
I think look at the antenna cable on the back of your first radio, if there is no problem, check the antenna on the ceiling, maybe it may be loose and don't go to the electrician right away. Wait a little while.
08.05.2020 20:34 # 3
izzetcanbas
Hello, the car was locked in the car park for 4 hours, then when I arrived, I started the car again, opened the radio, the same problem was going on. After I tampered with the menu, it was English, I turned it on to translate it on the phone, closed a few things, it improved. So the problem is from the menu. I connected the vehicle during the day and when I opened the doors and opened and closed the vehicle with the remote control, it was burning automatically, now they are not burning, now I will look at the electrician.
08.05.2020 20:34 # 4
I think the problem is related to the electrical system.
08.05.2020 20:34 # 5
izzetcanbas
I had previously tampered with the settings, and while I was playing the radio without interruption, it was writing information on the screen and then it was going on and then it was writing radio frequency. After that, there was a problem. After I tampered, the info warning is no longer available. On radio, he improved after him.
08.05.2020 20:34 # 6
Furkan979
Try to turn off rds from the settings.
08.05.2020 20:34 # 7
mburakaslan
If you are using the original tape, I think it's never tampering. They put the most damn radio I have ever seen in my car. Change the tape that I will change too. 50TL tapes are more beautiful than they are on.
08.05.2020 20:34 # 8
izzetcanbas
Yeah, but you changed it, you can't use the steering wheel control
08.05.2020 20:34 # 9
[QUOTE = izzetcanbas] Yes, but have you changed it, you cannot use the steering wheel control [/ QUOTE]
There are models that can be used, teacher. Smile
08.05.2020 20:34 # 10
maximusti
If there is a W / R (wired remote) input on the received tape, control apparatus are sold for 100 TL, it can be made compatible with the original control.
I am trying to make this apparatus myself for now, but I have not been successful yet.
08.05.2020 20:34 # 11
Furkan979
I think the radio of peugeot would be satisfactorily better than 50 liras.
