Radio Control Arm
08.05.2020 21:17 # 1
gezginavci
Hello friends, by switching to the Peugeot brand at the beginning of the week, I joined you by buying my first 2004 model 307 1.4 hdi.
Of course, since it is a 15-year-old vehicle, it is very normal to have some problems. My vehicle also has problems and bad situations that I later found out to be chronic. First of all, I will start to solve the problems caused by user errors before chronic problems. But respectively :)
The problem I should fix first is to remove the original music system and replace it with a cheap single tape. The screen does not show up in sunny weather during the day. First, I want to buy a new double device and fill the console. But the buttons on the end of the radio control handle are broken. It is necessary to buy a new one.
My question is, friends; Will a new double device and a new joystick work together? Will they be able to adapt to each other? Will an extra apparatus be required?
I would like to thank the friends who can provide information in advance.
08.05.2020 21:17 # 2
ersin61
Good luck. There are those that are compatible with the arm, of course, but the cost is expensive.
