radiators
08.05.2020 16:29 # 1
mustafa142434
hi friends peugeot 206 x design i have a 2005 model vehicle. There is a tightness in the heater core, water flows. When replacing the heater core, it is imperative to remove the body. there is no other alternative. Can I close the crack if I put it only from the powders sold in these radiators without changing it. thank you if you help me thank you
08.05.2020 16:29 # 2
yavuz25
those crack closure powders work, but you have to try it. It would be wrong to talk without knowing the size of the crack. Passing the pedals out there and someone had done it. Maybe it's you too.
08.05.2020 16:29 # 3
How did you know that the heater was cracked in honeycomb?
First of all, it is necessary to put the diagnosis well. It usually runs from its joint. If it is, the document below will see your work. If it is really in the heater core, whether or not the console is inserted varies according to the model.
http://forum.peugeotturkey.com/forum_posts.asp?TID=20250&title=soutma-suyu-aracn-%DDine-szmas -proble my Reviews
08.05.2020 16:29 # 4
sinan0343
same problem was in my car. I made it without removing the body. It can be done, but it is necessary to find the master. 130 TL
08.05.2020 16:29 # 5
mustafa142434
My brother is your peugeot 206 in your car because I went to the masters in Bolu. They say it cannot be done without opening the trunk.
08.05.2020 16:29 # 6
sinan0343
evt peugeut 206 x-design 2005 model is the same car.in my master said to me that if they went to another bio, they would have removed the body ..
08.05.2020 16:29 # 7
semih
Pedals can be removed from one place. Do not disassemble the vehicle. Best regards.
