radiators
08.05.2020 16:18 # 1
enes119
friends, the other day I was going to put on the radiators & nbsp; auto smell, and when I put it on, the rotating grills in it all got its head went to one side.
08.05.2020 16:18 # 2
Okay, that's broken.
If it doesn't break, it doesn't all show a different direction. / div>
08.05.2020 16:18 # 3
[QUOTE = maverick] okay it is broken.
not all of them show different direction if not broken. looks at different side.
The subject title you opened is completely different from the problem.
`` ventilation grille`` is your problem.
08.05.2020 16:18 # 4
enes119
Thanks for the information ... how will they be now? can i do it myself I thought I thought like honeycombs at home :)
08.05.2020 16:18 # 5
The broken part of the piece will probably appear after removing the grille.
If the broken piece is there, stick it with patexx.
is a complicated easy event. I am sending the link to the title.
in terms of guiding .... howil_yapilir.asp Article ID = 17 "target =" _ blank "rel =" nofollow "> http://www.peugeotturkey.com/nasil_yapilir.asp?MakaleID=17
08.05.2020 16:18 # 6
enes119
Thank you very much, I will do your first job tomorrow. & nbsp;
08.05.2020 16:18 # 7
Kemanyak
It is unbroken. There's a piece of rubber leaving it. You can force it out and put it on easily after you put it in place. The adhesive prevents the mechanism from working.
