Radiator Water
08.05.2020 15:22 # 1
artes34
Hello friends, I suppose I need to put pure water and antifreeze into this tank, which I have shown with the arrow mark in the picture.
08.05.2020 15:22 # 2
Put antifreeze brother but there is a level where there is max
08.05.2020 15:22 # 3
First, measure the condition of the water in it. Complete whatever you need (antifreeze or ready-made water (I hear pure water for the first time)) with it and immediately investigate the reason for the decrease in water. Cooling system does not reduce water to a halt.
08.05.2020 15:22 # 4
aclern
Pure water is often used in steam generating appliances. Like an iron, for example. I know it is enough to put ready water, not pure water.
08.05.2020 15:22 # 5
oguzhan29
You will put antifreeze there, as your other friend said, put it up to the max level.
08.05.2020 15:22 # 6
artes34
It is not over yet, but if I put a complete antifreeze that has reached a very low level,
08.05.2020 15:22 # 7
[QUOTE = artes34] It is not over yet, but if I put a complete antifreeze that has come down to a very low level, would it be [/ QUOTE]
No way! Antifreeze does antifreeze when mixed with a certain amount of water. Usually 50% antifreeze and 50% water mixture is made. However, many antifreezes sold today are actually sold ready. So there is no need for mixing. In fact, I couldn't find antifreeze when I looked here once. The ready ones are always sold. Take care when buying.
08.05.2020 15:22 # 8
cerci07
I would recommend you to try to find out why brothers do not decrease the water where the vehicle stops.
I think you can drain it completely and put water with 50% antifreeze.
08.05.2020 15:22 # 9
orhanetap
There are two lines in the hopper as max and min. You shouldn't cross the line.
Otherwise, I know if I have antifreeze and it smells dirty. Sırıtma
08.05.2020 15:22 # 10
goktug
Although my car is not frequent in reducing water. what could be the reason
08.05.2020 15:22 # 11
[QUOTE = göktuğ] my car is also not reducing water is frequent, though. what could be the reason? [/ QUOTE]
Check that the mats on the driver and passenger are wet.
08.05.2020 15:23 # 12
goktug
[QUOTE = koliva] [QUOTE = goktug] Although my car is not frequent reducing water. what could be the reason? [/ QUOTE]
okay let me see you tomorrow.
08.05.2020 15:23 # 13
cerci07
[QUOTE = Göktuğ] [QUOTE = koliva] [QUOTE = Göktuğ] My car is also not water-low, although not often. what could be the reason? [/ QUOTE]
okay let me see you tomorrow. [/ QUOTE]
If the mats are dry, look at the bottom of the timing belt under the vehicle.
08.05.2020 15:23 # 14
artes34
friends, thank you everyone for the cvps, I ask a lot of questions, but is there an antifreeze brand that you can recommend, thank you very much, you are helping, thanks ALLAH.
