Radiator upper part cracked
08.05.2020 19:41 # 1
baya1994
Hi 206 my diesel car has gone from the top of the radiator next to the plastic and the water is leaking, the region I have shown in the picture has changed the top tank, but I think the price is 80 TL, it is very expensive.
Give me an idea where the claws are located on the side where the plastic and aluminum joints are.
08.05.2020 19:41 # 2
teacher do repairs but then you will encounter the same problem, that solution will be temporary. it would be better for you to replace it completely. Around 180 TL original radiator.
08.05.2020 19:41 # 3
pusutr
Apparently, the plastic piece is pretty old. Changing would be healthier.
If you absolutely want a workaround,
http://urun.n11.com/diger/tavan-citasi-yapistirici-dayson-siyah-silikon-ucretsiz-kargo-p63660495?cid=604001&gclid=cj0keqia6vs2brdh8dq06ydhz_ıbeiqazndbmraqat7_rkr42yovjhssb1pmsjw1gsy1n8b7clrrtkcaak408p8haq&gclsrc=aw.ds
. apply a lot of the product (dyson silicon) here. I attached these to the turbo hose at the time. He managed me until he got a new one.
08.05.2020 19:41 # 4
cagriaktas
unrelated to the subject, but today the flap motor malfunction came out in control ... did not blow cold air conditioning ... I paid 330 rubles in a tiny piece from the matchbox with 2 tiny plastic impellers and a tiny motor ... ...
08.05.2020 19:41 # 5
baya1994
brother, thank you very much tomorrow i will try to go to the ironmongery and hopefully the benefit will work if the pilastic is closed.
08.05.2020 19:41 # 6
burakrak53
As my son said, radiator work does not come to joke, I think, buy a new radiator is not very costly, it will not leak easily in the crack. In my old car, it was cracked once, because the radiator fan socket did not open the fan just because it was overheated and cracked, if you buy a new one, open it to the fan in time.
08.05.2020 19:42 # 7
baya1994
Hello friends, I have been traveling in the industry for a few days. To change the plastic in the top, they give me a figure. Anyway, I did some research and found the paste produced by 404 companies. It looks like a yellow play dough. I mixed it and put it completely on the ground and it became like steel after 4 hours. I put the water there was no pouring and they said that it was resistant up to 200 degrees. There is no problem at all, even if it is a short time in the car, can the bat be solved for 8 TL?
