Radiator transports water
08.05.2020 19:06 # 1
koray.turan
The plugs in my vehicle have changed everything today, the problem is still going on. the thing is that the water carries water from the water tank sometimes when it stops and sometimes when the engine stops Sometimes sometimes all of them are half an abnormality gozukmuyo parts etc etc
we don't solve the event and i keep researching it, i'm in a good mood. I would appreciate if anyone who knows about this topic helps. good forums koray206rg 2015-02-16 21:16:50
08.05.2020 19:06 # 2
Barut
Have you looked at the lid of the water bowl? Usually the problem is the wear of the cover gasket. The water level should be in the middle of the min max text written on the drum.
08.05.2020 19:06 # 3
monalos
Yalçın brother where is the max level I can not find it anyway: I look at the D lamp I could not see the level on the canister
08.05.2020 19:06 # 4
koray.turan
[QUOTE = Red dream] Have you looked at the lid of the water bowl? Usually the problem is the wear of the cover gasket. The water level should be in the middle of the min max text written on the drum. [/ QUOTE]
Bro, now i bought it
08.05.2020 19:06 # 5
koray.turan
[QUOTE = monalos] Yalçın brother where is the max level I can not find it anyway: I look at the D lamp I could not see the level on the canister [/ QUOTE]
My brother is writing on the right side and there is the same color as the canister above him.
08.05.2020 19:06 # 6
Barut
[QUOTE = monalos] Yalçın brother where I can not find the max level or not: I look at the D lamp I could not see it on the canister [/ QUOTE] writes the level in the middle of the canister. Look carefully, maybe the text is on the back, because the drum is spinning.
08.05.2020 19:06 # 7
xmen
When my teacher is idling like this, open the bonnet and see if someone is trying to gas, water is trying to squirt. So watch the situation, let's see what's going on.
08.05.2020 19:06 # 8
themurat54
Could this fever thing be an indicator of heat?
When I showed the master to replace the radiator that the water was missing, he said that the car seemed overheated.
08.05.2020 19:06 # 9
berk2309
If my teacher radiator hoses heat up and harden, the oil mixes with water (see where you put the water.
08.05.2020 19:06 # 10
koray.turan
Friends, I changed the cover, do you believe that the temperature values of the car froze 3 months ago, a cover could have been so effective
08.05.2020 19:06 # 11
koray.turan
[QUOTE = themurat54]
When I showed the master to replace the radiator that the water was missing, he said that the vehicle seemed overheated.
Show it elsewhere and get a definite result. My problem is the cover has changed. Everything has returned to normal.
08.05.2020 19:06 # 12
themurat54
[QUOTE = koray206rg] [QUOTE = themurat54]
Show it elsewhere and get a definitive result. My problem is that I changed the cover output.
No, I said it for you :) Unfortunately my gasket was burned.
08.05.2020 19:06 # 13
koray.turan
Sorry, my problem has improved for now. There was no gasket burn or any negativity. It looked like the cover was all right, but the cover was at least not a problem for now.
08.05.2020 19:06 # 14
niyazi0635
Sorry my friends, I'm new to both the pegeout brand and the forum, so I write here. There is an original valeo water radiator for 150 lira for 260 lira. Does it cause 150 problems in summer? Also the original one is valeo. Meanwhile my car is 98 sedan 306 xn without air conditioner model. Do you know an address where I can order the spare part clearly, thanks
08.05.2020 19:06 # 15
berk2309
Don't worry my teacher from the original, give more than 100 dollars.
08.05.2020 19:06 # 16
niyazi0635
Exactly berk2309 important part, especially in summer, to make trouble in Kuşadası heat
08.05.2020 19:06 # 17
niyazi0635
friends mobility indicator 90 is not normal value?
08.05.2020 19:06 # 18
koray.turan
Yes 90 normal value
