radiator problem
08.05.2020 16:34 # 1
YUNNES37
& nbsp;
I gushed water from the radiator while friends were looking. overheating caused 90 and so on.
08.05.2020 16:34 # 2
YUNNES37
I went to the mechanic closed the stopper, I came home & nbsp; 2 km or so I opened the radiator cover
08.05.2020 16:34 # 3
djchaos
When the radiator of the vehicle makes an air jam, it will break out from one place, you need to get the air out if it cannot blow out the air, it will damage the engine.
08.05.2020 16:34 # 4
YUNNES37
I think there was something that caused the air, we put water in the evening, we got the air.
We traveled 2 km. we opened the radiator cover and water splashed again.
& nbsp;
waiting for your comments
08.05.2020 16:34 # 5
okankrgz
What is a vehicle?
08.05.2020 16:34 # 6
YUNNES37
vehicle 306
2000 model lpg li
08.05.2020 16:34 # 7
06OzGuR06
Isn't antifreeze placed? I think that if water was antifreeze, that water should not be gushing.
08.05.2020 16:34 # 8
YUNNES37
friends vehicle & nbsp; fan sender is broken. When the fan does not work, the water in the radiator does overheating & nbsp; it is gushing when the door is opened.
the sender has changed, do you think it makes sense as if it is ok now.
08.05.2020 16:34 # 9
yavuz25
When the engine is hot, the radiator cover is not opened when heated. The radiator cover is not a part to open every two. "Smile" I think it Do not play with the cover until you are getting air. Take the air and do not hit your hand. It will not be a problem. If the piece you want is damaged, it will make the water boil. "Wink"
08.05.2020 16:34 # 10
albayman
We must check the temperature with our eyes repeatedly while the vehicle is running and waiting in the city. If the fan sender is not working, the water temperature rises (if we are not making roads) and it can exceed the boiling point. we can see this change in the temperature indicator. & nbsp; water does not boil in the closed circuit water system, but when it opens the lid, it sprays due to pressure.
08.05.2020 16:34 # 11
malazgirt18
temperature and idling like a nightmare :)
08.05.2020 16:34 # 12
yavuz25
[QUOTE = malazgirt18] like heat and idle nightmare :) [/ QUOTE]
is no problem for a properly working engine "Wink"
