radiator hoses swell
08.05.2020 16:45 # 1
YUNNES37
Friends
& nbsp;
My car peugeot 306 2000 model lpgli and automatic gearshift
& nbsp;
my car's thermostat, circulation, radiator, sliding door gasket changed on the cover It pelted with stones. I did about 500 km, I did not do on different days.
but & nbsp; vehicle & nbsp; now & nbsp; let it work for 5 minutes. >
said the repairman may need to change the cover to remove the cover again, but the cover was sent on the saw.
& nbsp;
you might cause this problem. & nbsp;
YUNNES37 2012-05-09 16:51:50
08.05.2020 16:45 # 2
monur
When the engine is running, open the cover of the water expansion vessel, if the water starts to flow and overflow after a certain period of time, the cylinders are compressing upwards. >
B- The cover may not be tightened at the required torque values,
C- The gasket may not be fully seated, or there is a damage,
D- The cylinder head may not accept grinding
If the engine does not overflow when you press the gas while the engine is running or does not overflow after idling while the engine is running (with the lid open)
When you change the cover of the expansion vessel, your problem will be fixed.
08.05.2020 16:45 # 3
YUNNES37
I understood, for these reasons, does it mean that it could be something else?
With the cover of the expansion vessel closed, let the vehicle run & nbsp; 2 min & nbsp; stop. I open the lid, throwing all the water out of the lid.
& nbsp;
08.05.2020 16:45 # 4
EmSul
Friends, does this radiator hose normally have to be always soft? Now, when I read this, the wolf fell into me, I went to the last industry, I stood in front of the shop, it was very hot, the engine was hot as a weather ... I stopped the car, the LPG setting would be made, I opened the hood, so I touched a radiator hose, it was almost hard like a stone. He never said anything to the master.
08.05.2020 16:45 # 5
taskin
Honda had been in my car, had such troubles from the scraping belt go come & nbsp; When I got bored, I showed it to another master.
