RADIATOR FAN WORKS FREQUENTLY
08.05.2020 18:48 # 1
eneskaleli35
friends I have 207 sportium vehicles, the radiator fan is working even when the temperature indicator is normal or it starts to work after stopping the vehicle (the temperature indicator is at normal value)
08.05.2020 18:48 # 2
suppor
I come into play very little, I complain, the pressure goes too much, I want to neglect the vehicle, if the car does not overheat, it enters more than diesel.
08.05.2020 18:48 # 3
Efe-Pojo
The fan of the 207 has 2 circuits, the low-energy operator usually starts up quickly and continues when the vehicle is not running, normal. Especially Izmir is good because it is a hot place.
08.05.2020 18:48 # 4
uluhanmert
hi arkads me too i got bored with a fan i have pejo 106 xs automatic gear has two fans, the car gets hot when it gets warm, the car hurts, the two cuts the power to the car, it absorbs the electricity, it gets churned, the car bursts with less touch of gas, the car breaks out, the fan is silent, the car breaks out, the car breaks out, the car breaks out, the car breaks out, the car breaks down I don't need to run the 2nd fan, or if we change my way to the fan, let's see if it's left from the feast.
08.05.2020 18:48 # 5
Efe-Pojo
It seemed strange to me that there was 2 fAn in 106. not get stuck later? I wonder if you can put the picture.
08.05.2020 18:48 # 6
uluhanmert
I saw the god first time in a car, two fans looked at the master, there were two fans. The problem of the vehicle, in other words, the water runs in the halves, and it runs halfway through the fan. I will try it, I think that when I say there are no 2 fans in the leaked pejo, I will try one fan.
08.05.2020 18:48 # 7
uluhanmert
I looked at the net a little, I found the biped pejo, I did not understand it, I have this bite
uluhanmert 2014-10-04 22:56:36
08.05.2020 18:48 # 8
kaderim@61
hello brother 106's especially 1.6 engines have double fans because of the fact that the engine heats up very quickly because of the power of the engine, so it has to cool down quickly, so it has double fans.
it is probably caused by the dynamism of the charger, it draws the battery, it disrupts the vehicle's ignition system, I hope you get it easy
08.05.2020 18:48 # 9
uluhanmert
Thank you, I hope
