Radiator crack
08.05.2020 17:52 # 1
vbmaster
Dear friends;
My car, which I gave to a acquaintance during the feast, boiled water. they poured water into the radiator and added water. Now the problem is the plastic on the top of the radiator is cracked. Is it possible to repair?
my second question is did adding water damage the hot engine? How do I know if he gave? The car still smells of plastic, but there is no problem with traction. I can add water and go, but half of 50 km ends.
I am waiting for an urgent answer from my masters.
thank you so much ...
08.05.2020 17:52 # 2
Bunyamin.Kar
If the plastic is cracked, there is no repair, it happened to me, there was a glue called sun-fix, it will last 2-3 months, but I think it will lose its feature because of the heat, you will either find a radiator or you will get a new radiator.
08.05.2020 17:52 # 3
sezar206
The cylinder head gasket may be burnt out. When he overheats. If it does not decrease the water from the radiator, let it run. How did they boil the water or did they not see the heat?
Come on, let's see a lot of work. Even if you don't give a trip and give it, you would have trouble.
08.05.2020 17:52 # 4
vbmaster
How do I know if the cover gasket is burned ...
08.05.2020 17:52 # 5
samet206
Whatever we say from here, if the empty radiator cracks, show your vehicle that water should be added when the water is hot, this should not be done. . If the engine of the water source is stopped (if it is stopped), it is more likely to burn the gasket. If I do not know the gasket burning symptoms fully, the gasket burned if the car is constantly overheating and the oil is mixed with water.
08.05.2020 17:52 # 6
vbmaster
The situation is that the radiator has changed this day, I gave 170 lira in the evening. they never stopped the engine. First of all, they had antifreeze in the vehicle, mixed with water and added so that it would not hurt. I already know there is a leak, I do not know if it boiled water from it, I hope so, is there a friend who knows how to know if the gasket burned and the gasket burned? If it was not burned, why did the water drop out after the radiator?
I wonder if the car says sell me :)
08.05.2020 17:52 # 7
vbmaster
with knowledge?
08.05.2020 17:52 # 8
cansytnn
I guess the car has burned the gasket but I don't know exactly my 307 im has been traveling with burnt gasket for 3-4 months now, the problem is not solved.
In April, the vehicle was overheated, we stopped the engine and started it 2 minutes later, the hot air heater was running at 4th speed, we went slowly, half an hour or so, then the temperature dropped to 90, then the vehicle was constantly decreasing water, the trip computer said COOLANT LEVEL TOO LOW. It gives the warning right now, it still gives us 2-2.5 liters of water. There are so many masters in the trunk, some say gasket burns, some says there are holes in one of the octopus hoses, some say there is a problem in the cylinder head, there is no opportunity and we couldn't make the vehicle, hopefully we will have the vehicle built in the shortest time but the vehicle did not solve the problem more properly. Did the water drop? We ran the vehicle at idle for 1 hour. There was no 1 gram of water in the industry. The water is constantly decreasing when it moves under the vehicle, but we don't know where it is.
08.05.2020 17:52 # 9
vbmaster
your situation is very interesting. Get well soon. Does anyone know how I can understand this gasket burning business?
08.05.2020 17:52 # 10
samet206
Sir, I say that if there is no leakage, even though the radiator changes, if your car decreases water, and if it is hot, open it, check the lid of the water reservoir where you add water, if the oil and water are mixed together, this means that you burn the gasket when water was like a slime. I think it is nice to check if the radiator connections hoses under the mop of the driver's seat are leaking.
08.05.2020 17:52 # 11
vbmaster
There is no slime.
08.05.2020 17:52 # 12
error
get well soon, a difficult situation ..
08.05.2020 17:52 # 13
vbmaster
God bless you, I wish you an accident-free day ...
08.05.2020 17:52 # 14
cansytnn
What happened?
08.05.2020 17:52 # 15
vbmaster
I did not use it in the evening, but I looked down and looked like there is a water drop, but there is no trace of the gasket burn to make sure there is water in the canister.
08.05.2020 17:52 # 16
ertanakar
On the second day of the holiday, my friend had a half engine built, I gave 900 pounds, including workmanship, I did not throw any water on the floor, I did not change the visible hoses, I continued by putting water like this for 3-4 months. At the same time, it worked hard, I couldn't run it anymore, my mechanic played it back and forth, it didn't work with the battery reinforcement and knock. water comes out, I fill the water canister inside the hood, it throws it from the exhaust, I don't write my mechanic's operating tactic especially so you don't get used to it Big smile I think it was too long, I officially washed the inside of the engine with water.Allah, my mechanic was good, he worked until the evening until the evening, grinding or something, he handed it to me in the morning. But over time, he had not been able to predict when the water would fall to the bottom ...
08.05.2020 17:52 # 17
vbmaster
My teacher, God bless you, I was so bad now how much water were you putting in every ride or day? Is the gasket burnt
08.05.2020 17:52 # 18
ertanakar
I was filling 2 liters in 2 days, yes the gasket was burnt and giving water to the cylinder.
08.05.2020 17:52 # 19
vbmaster
Do I know if I look at the exhaust?
08.05.2020 17:52 # 20
ertanakar
No, you can't understand ... I tried every way because it's not gasket, but at first it turned out Cry I was tired of the car, I did not notice it, but I did not realize, but now it has been done for at least 4 years, and it has started to run well. - they mix oil into water - they said they throw water from the exhaust, but there was none, but I still witnessed it, I gave the water from the gasket to the cylinder, from the direct gasket burned to it.
Page : / 2
