r also goes forward.
08.05.2020 19:27 # 1
selahattin
Hi guys, today I changed the selonoids of my 307 automatic gearbox. Everything is normal. After replacing everything, I put it back properly. Then I started the car, all the indicators were normal, so prn d. I said, let's do a trial swarm, got out, took a turn, the gears are very normal. But when I dropped the car into r, the car was not going back. He even goes forward when he gives some gas. The display shows the screen as r, but the vehicle does not go back. What could be the problem?
08.05.2020 19:27 # 2
berk2309
As far as I know, my teacher needed to renew the software after changing the solenoids yourself. I think if there is no problem about this, I think there may be a problem with his contactor or brain.
08.05.2020 19:27 # 3
selahattin
I changed it myself. There was no such problem before. It works perfectly in other positions, only R is also a problem. When I take it to R, the transmission will sound in the form of a sizzling sound in the electro I`m part, only in R
08.05.2020 19:27 # 4
berk2309
I think it might be a software problem.
08.05.2020 19:27 # 5
talip206
Hodja, there is an adjustment point in the engine part. It is necessary to make adjustments from there. My solenoid had mastered it. I don't think the problem is software related
08.05.2020 19:27 # 6
talip206
Bidet sizzle is normal, but I don't remember which gear it was coming in.
08.05.2020 19:27 # 7
selahattin
where exactly is this tuning on the engine? vehicle peugeot 307 1.6 16v gasoline 2006 model
08.05.2020 19:27 # 8
GokhaN
they adapt when the solenoid changes but I don't know exactly how it is made
