quiver axle motor
08.05.2020 20:07 # 1
ahmetdurna78
We have 206 models of 2004 model but we are in trouble with it; front tremor when driving by car ... not in the ears of the engine, no shaking when running in the morning ... as if the floor is shaking, there is no tremor coming from the steering wheel, especially when the ramp goes up, it feels so much when it pulls your foot off the gas, it starts to shake when I press the throttle, and the gear swings on the arm, lightly on the clutch swinging happens. They said the axle 3 times axle change but did not cut. new axle is mounted 2-3 days nothing happens then restarts not to be nervous I couldn't find the reason please I can help someone who encounters this malfunction, I am looking for a solution
08.05.2020 20:07 # 2
xmen
Is tremor only in motion. Or is it both idling and moving.
08.05.2020 20:07 # 3
firstly welcome. The axles sub-industry can be disrupted too. the front team was checked in detail. front wheel hub etc.
08.05.2020 20:07 # 4
ahmetdurna78
It's moving, when you press the gas, the base is shaking, the head is shaking. There is no problem when it is not pressing the gas.
08.05.2020 20:07 # 5
ahmetdurna78
We are supplying the supplier industry, originally 1100 TL. The subject I am amazed is that you go maximum 200 km and it repeats 2-3 days later. Whoever I went to, says the axle. Let's say flat asphalt on the road I go makes bad road but no room.
08.05.2020 20:07 # 6
dejawu1978
the problem is in the ears of the motor
08.05.2020 20:07 # 7
ahmetdurna78
solved with a washer
08.05.2020 20:07 # 8
boruc
[QUOTE = ahmetdurna78] solved with one washer [/ QUOTE]
How did it go, hod? Where is the stamp?
Can you give me more information here? I may have a similar problem Fitters 2017-09-16 12:00:21
08.05.2020 20:07 # 9
Kocak
or was the stamp on the clutch wire or something?
08.05.2020 20:07 # 10
gn461
We look forward to where the stamp is :)
08.05.2020 20:07 # 11
barisnikof
all eyes are flakes:)
08.05.2020 20:07 # 12
meteora
We are waiting for the stamp :)
08.05.2020 20:07 # 13
Selox
pul
08.05.2020 20:07 # 14
What kind of stamps did I wonder? Smile
08.05.2020 20:07 # 15
bjkamil
that stamp will come here !!
08.05.2020 20:07 # 16
keqir
08.05.2020 20:07 # 17
ggitaristt
Let me park there stamps.
08.05.2020 20:07 # 18
Selox
But I could not `` PUL '', `` PUL``, I could not `` PUL``.
08.05.2020 20:07 # 19
ahmetdurna78
They made a 5-millimeter washer between the wheel and the axle. I'm sorry I could not enter how long I could write an answer.
08.05.2020 20:07 # 20
ahmetdurna78
They put a 5-millimeter washer between the wheel and the axle. Generally, nobody approaches, for some reason.
Page : / 2
