Quicksilver transmission |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 18:13 | # 1 |
ozzy_0703 |
| 08.05.2020 18:13 | # 2 |
Can Oksuz |
As you mentioned in my car (corsa 2004), I had a problem. It was only going to 3 and 4. Since I had to lift at 3, it stopped if it was not loaded into the lining. The ends of the black piece that I added in the picture in the gear lever mechanism has been displaced because it lost its function. He had come out and bought it. If the shift lever mechanism is also at 206, the question may arise from this.
| 08.05.2020 18:13 | # 3 |
ozzy_0703 |
I don't think it will be from the gear lever mechanism.
| 08.05.2020 18:13 | # 4 |
Can Oksuz |
Have a look. I hope there will not be a high amount. My gear knob was falling left and right when idle. I thought I was wearing 1e, whereas 3e was the gear. It was also because he did not go when it was installed. I said let me share it.
| 08.05.2020 18:13 | # 5 |
ozzy_0703 |
I understand, thank you for your help.
| 08.05.2020 18:13 | # 6 |
[QUOTE = ozzy_0703] I don't think it will be from the gear lever mechanism, I understand the ball sounds when the gear shifts idle to the left and right. I hope it comes out in those neighborhoods, I have a F1 transmission in my vehicle. 1260 pounds costs :( get past, that's why I am against giving a car.
| 08.05.2020 18:13 | # 7 |
[QUOTE = ozzy_0703] hello I gave my Quicksilver vehicle to this friend and when it came back it was not going into reverse gear, it was going into gear 1 and 2, it was not going to go to 3 and it was not going back, did I think that the vehicle was not walking and stopping when I put it in first gear? And if anyone knows how much it costs, I would appreciate it if they answer. [/ QUOTE] My friend uses the car and the computer, you use the car, your friend uses the car when the life of the part is 5 years. While using it, the economical life of the piece ends and it is the fault of your friend. Or you make your car, you can use it by looking like an eye, your friend's hand brake will pull gears from 6,200 rpm.
| 08.05.2020 18:13 | # 8 |
ozzy_0703 |
cheap ripped friends, where the gear is connected, instead of repeat tactics, the friend had a hard time yesterday we saved the car with 15 lira heat
| 08.05.2020 18:13 | # 9 |
volkanC2 |
get well .. Doğan said that one person uses the car and computer ..
| 08.05.2020 18:13 | # 10 |
ozzy_0703 |
thanks. because it's not that kind of toy because
| 08.05.2020 18:13 | # 11 |
Can Oksuz |
I am glad you get over cheap. Get well soon.
| 08.05.2020 18:13 | # 12 |
KenBlockJR |
106 or 206?
| 08.05.2020 18:13 | # 13 |
ozzy_0703 |
Thanks
| 08.05.2020 18:13 | # 14 |
ozzy_0703 |
106
