Question about the 307 clutch ...
08.05.2020 19:23 # 1
raconcu
Hello friends my 2006 model 3071.6 hdi make-up case. I'm very particular about my friends car, from time to time, I check all of the steering fluid, brake fluid, oil level, water level. My question to you is the clutch of the 307s hydraulic? I couldn't see your tank. Or is it an old-style wire system? Many thanks for your help in advance.
08.05.2020 19:23 # 2
raconcu
Guys, there are no 307th people in the huge forum? Won't anyone help?
08.05.2020 19:23 # 3
bozkurtum
Slm .. I have the same vehicle .. All the flywheels I know are mobile .. I don't know if there is hydraulic .. how many of you .. .. is it time to change?
08.05.2020 19:23 # 4
raconcu
Hodja was my new 137,000 vehicle 1.6 hdi
08.05.2020 19:23 # 5
madblueblacksea
It has to be hydraulic. I say I need it because it can vary depending on the model. As seen below, the hydraulic center is hydraulic if it is sold in the market. So many sites need it, so if you searched the clutch wire in the goolede, the problem would be solved Big smile
08.05.2020 19:23 # 6
raconcu
My teacher, I asked this question, I can't see the hydraulics. 307. Can someone show me where the clutch hydraulic tank is?
08.05.2020 19:23 # 7
madblueblacksea
Follow the connections to the Firen hydraulic container, they can use the same box
08.05.2020 19:23 # 8
raconcu
I don't know if it's the same box, but if it's a box, it's full. I'm adding Dot 4.
08.05.2020 19:23 # 9
sdttn
Uses clutch hydraulic and brake hydraulic fluid.
