Question about speakers!
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
08.05.2020 18:08 # 1
rifatseker
Hello friends ,
I think of the speaker below for the front door. I am thinking of removing the 2 pioneer speakers on the front door and replacing it. There is a 13 cm pioneer in the back door. If I just put these two on the front side, I would drive with a tape recorder without amplifier, what would the sound quality be like? I do not like to listen to music at very high volume. Can I get the full bass sounds that sound nice on the middle level? I hope I could explain my problem.
Tape installed in my car Sony DSX-A30 4x50w with Mosfet output
The speakers I intend to get to the front door.
08.05.2020 18:08 # 2
rifatseker
So can I get an amp recommendation, guys, just to feed these two speakers?
08.05.2020 18:08 # 3
rifatseker
There is no sound system in my car :) I just wanted to change these two speakers to get a better quality sound. Pioneer 16 cm in front 13 cm in back. There is also a Sony DSX-A30 tape, nothing more in the car. My problem is that the sounds sound louder, even if they don't. :)
08.05.2020 18:08 # 4
samet206
Anyway, it is not a device that is used to get the sound of rumble in the amphitheater, it is used to improve the sound, it removes its sets with some original tapes, but it does not work without amphitheater, it does not make sense to connect without an anfull, and a nice mud team is at least 200 TL. It will give the same taste in a 60 TL loudspeaker if you are going to connect without amplifier.
08.05.2020 18:08 # 5
rifatseker
Ok guys, thank you, we will look at one amp. :)
08.05.2020 18:08 # 6
Alicilik
Tape output cancel, teacher.
Running JBLs without amps is risky. It works in low volume but you can not get efficiency. If the output is 4 * 50, this is the peak value and it should be 22-23 w rms on the basis of RMS. You will attach a 70w rms speaker to it.
08.05.2020 18:08 # 7
Feyribas
I do not recommend ... I used it at 206 m, I was not satisfied ... Treble is very bad, there is no emphasis on bass ...
